Microcontroller stops working when I slow down the clock - Where do I even begin to debug this?
Question asked by arnold_w on Jul 11, 2016
Latest reply on Jul 11, 2016 by peacock.jack
I am working with the STM32F405 microcntroller and in main() I have the following loop:
while (TRUE)
    UART_TransmitNullTerminatedString((uint8_t*) "\r\nMicrocontroller alive ");
I run this firmware on 2 different PCB:s and it's working fine on PCB #1, but on PCB #2 it hangs after 3-4 seconds. Now, it would be easy to conclude that PCB #2 is broken, but the strange thing is that PCB #2 starts working fine if I run the microcontroller faster. I use the following code to switch clock frequency:
void ClockSwitch(ClockFreqType clockFreq)
    // The code below was taken from HAL_RCC_DeInit() in file stm32f4xx_hal_rcc_ex.c
    /* Set HSION bit */
    SET_BIT(RCC->CR, RCC_CR_HSION | RCC_CR_HSITRIM_4);
    /* Reset CFGR register */
    CLEAR_REG(RCC->CFGR);
    /* Reset HSEON, CSSON, PLLON, PLLI2S */
    CLEAR_BIT(RCC->CR, RCC_CR_HSEON | RCC_CR_CSSON | RCC_CR_PLLON| RCC_CR_PLLI2SON);
    /* Reset PLLCFGR register */
    CLEAR_REG(RCC->PLLCFGR);
    SET_BIT(RCC->PLLCFGR, RCC_PLLCFGR_PLLM_4 | RCC_PLLCFGR_PLLN_6 | RCC_PLLCFGR_PLLN_7 | RCC_PLLCFGR_PLLQ_2);
    /* Reset PLLI2SCFGR register */
    CLEAR_REG(RCC->PLLI2SCFGR);
    SET_BIT(RCC->PLLI2SCFGR,  RCC_PLLI2SCFGR_PLLI2SN_6 | RCC_PLLI2SCFGR_PLLI2SN_7 | RCC_PLLI2SCFGR_PLLI2SR_1);
    /* Reset HSEBYP bit */
    CLEAR_BIT(RCC->CR, RCC_CR_HSEBYP);
    /* Disable all interrupts */
    RCC->CIR = 0x00000000;
    // First, switch to HSI to bypass the PLL
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
    HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7);
    // The code below was generated with STM32CubeMX
    switch (clockFreq)
        case CLOCK_FREQ_1_MHz:
            RCC_OscInitStruct.HSICalibrationValue = 16;
            HAL_RCC_OscConfig(&RCC_OscInitStruct);
            RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV16;
            break;
        case CLOCK_FREQ_2_MHz:
            RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV8;
            break;
        case CLOCK_FREQ_4_MHz:
            RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV4;
            break;
        case CLOCK_FREQ_8_MHz:
            RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
            break;
        case CLOCK_FREQ_16_MHz:
            break;
        case CLOCK_FREQ_32_MHz:
            RCC_OscInitStruct.PLL.PLLM = 8;
            RCC_OscInitStruct.PLL.PLLN = 64;
            RCC_OscInitStruct.PLL.PLLQ = 4;
            break;
        case CLOCK_FREQ_64_MHz:
            RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
            break;
        case CLOCK_FREQ_128_MHz:
            RCC_OscInitStruct.PLL.PLLN = 128;
            RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
            RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
            break;
        default:
            break;
    HAL_RCC_ClockConfig(&RCC_ClkInitStruct, getNumWaitStates(clockFreq));
    SystemCoreClockUpdate();
At 8 MHz PCB #1 is working fine, but PCB #2 hangs after about 3-4 seconds. If I instead run at 16 MHz or faster, then both PCB:s work fine. Does anybody have any suggestions how I can tackle this problem? Are there any status registers I should pay attention to? I'm running off a power supply and power consumption doesn't seem to be an issue (it's not drawing too much current and, surprisingly, the current consumption doesn't go down after PCB #2 hangs).
