Timer Encoder Mode Oddities
Question asked by shingadaddy on Jul 5, 2016
Latest reply on Jul 5, 2016 by shingadaddy
Well if you have stared at the data sheet and user manual like I have for a bit and tried to get an encoder running "understandably" / "predictably", you might hit some slippery curves. Don't underestimate the curves the ENCODER ITSELF can throw in. the encoder I had picked for me was a nice cheap quadrature encoder by Bourns.
ECW1D-C24-CC0024L .
I was half expecting that this was the usual encoder output. It has 24 click/detents per revolution and I figured 1 edged change per click. Repeating a quadrature cycle 6 times in 360 degrees.
   < WRONG >
I get 1 FULL QUADRATURE CYCLE per click. YES PER CLICK!....
So if things go weird - first make sure your encoder does what you expect.
Sheeesh...
I'm still fumbling around with the timer setting to see if I can get a count of 1 per click out of the TIMER counts (TIMx->CNT) but short of a manual coding of a single right bump ( little endian) I haven't found it yet.
Suggestions?
