STM32F0 - TIMER ALERT A - not working please advice
Question asked by maor.yaniv.001 on Jun 21, 2016
Latest reply on Jun 21, 2016 by maor.yaniv.001
Hello  ,
please your's help , the timer should alert every second . it is only execute once .
and not working ....how ever i sent the time via uart from main() and i se the timer do working ....
here the code :
  * File Name          : main.c
  * Date               : 21/06/2016 01:59:09
  * Description        : Main program body
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f0xx_hal.h"
/* USER CODE END Includes */
ADC_HandleTypeDef hadc;
RTC_HandleTypeDef hrtc;
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_ADC_Init(void);
static void MX_RTC_Init(void);
static void MX_USART1_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
uint8_t aShowTime[50] = {0};
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_ADC_Init();
  hrtc.Instance = RTC;
  MX_RTC_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* USER CODE BEGIN 3 */
  /* Infinite loop */
  while (1)
//HAL_UART_Transmit_IT(&huart1,"test \r\n",10);
HAL_Delay(1000);
    RTC_DateTypeDef sdatestructureget;
  RTC_TimeTypeDef stimestructureget;
  /* Get the RTC current Time */
  HAL_RTC_GetTime(&hrtc, &stimestructureget, FORMAT_BIN);
  /* Get the RTC current Date */
  HAL_RTC_GetDate(&hrtc, &sdatestructureget, FORMAT_BIN);
  /* Display time Format : hh:mm:ss */
  sprintf((char*)aShowTime,"%02d:%02d:%02d\r\n",stimestructureget.Hours, stimestructureget.Minutes, stimestructureget.Seconds);
HAL_UART_Transmit_IT(&huart1,aShowTime,12);
          HAL_GPIO_TogglePin(GPIOC,GPIO_PIN_8);
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSI14
                              |RCC_OSCILLATORTYPE_LSI;
  RCC_OscInitStruct.HSI14State = RCC_HSI14_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.HSI14CalibrationValue = 16;
  RCC_OscInitStruct.LSIState = RCC_LSI_ON;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL12;
  RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_RTC;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
  PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
  __SYSCFG_CLK_ENABLE();
/* ADC init function */
  ADC_ChannelConfTypeDef sConfig;
    /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC;
  hadc.Init.Resolution = ADC_RESOLUTION12b;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.EOCSelection = EOC_SINGLE_CONV;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = DISABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = DISABLE;
  hadc.Init.Overrun = OVR_DATA_PRESERVED;
  HAL_ADC_Init(&hadc);
    /**Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_28CYCLES_5;
  HAL_ADC_ConfigChannel(&hadc, &sConfig);
/* RTC init function */
  RTC_TimeTypeDef sTime;
  RTC_DateTypeDef sDate;
  RTC_AlarmTypeDef sAlarm;
    /**Initialize RTC and set the Time and Date
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  HAL_RTC_Init(&hrtc);
  sTime.Hours = 0;
  sTime.Minutes = 0;
  sTime.Seconds = 0;
  sTime.SubSeconds = 0;
  sTime.TimeFormat = RTC_HOURFORMAT12_AM;
  sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sTime.StoreOperation = RTC_STOREOPERATION_RESET;
  HAL_RTC_SetTime(&hrtc, &sTime, FORMAT_BCD);
  sDate.WeekDay = RTC_WEEKDAY_MONDAY;
  sDate.Month = RTC_MONTH_JANUARY;
  sDate.Date = 1;
  sDate.Year = 0;
  HAL_RTC_SetDate(&hrtc, &sDate, FORMAT_BCD);
    /**Enable the Alarm A
    sAlarm.Alarm = RTC_ALARM_A;
sAlarm.AlarmDateWeekDay = 1;
sAlarm.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_DATE;
  sAlarm.AlarmMask = RTC_ALARMMASK_DATEWEEKDAY|RTC_ALARMMASK_HOURS|RTC_ALARMMASK_MINUTES;
  sAlarm.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_ALL;
     sAlarm.AlarmTime.TimeFormat = RTC_HOURFORMAT12_AM;
     sAlarm.AlarmTime.Hours = 9;
  sAlarm.AlarmTime.Minutes = 2;
  sAlarm.AlarmTime.Seconds = 1;
  sAlarm.AlarmTime.SubSeconds = 0;
  HAL_RTC_SetAlarm_IT(&hrtc, &sAlarm, FORMAT_BCD);
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling = UART_ONEBIT_SAMPLING_DISABLED ;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  HAL_UART_Init(&huart1);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  /* GPIO Ports Clock Enable */
  __GPIOA_CLK_ENABLE();
  __GPIOC_CLK_ENABLE();
  __GPIOD_CLK_ENABLE();
  __GPIOB_CLK_ENABLE();
  /*Configure GPIO pin : PA0 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  /*Configure GPIO pins : PC8 PC9 */
  GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9;
  GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
  /*Configure GPIO pin : PD2 */
  GPIO_InitStruct.Pin = GPIO_PIN_2;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pin : PB3 */
  GPIO_InitStruct.Pin = GPIO_PIN_3;
  /*Configure GPIO pin : PB4 */
  GPIO_InitStruct.Pin = GPIO_PIN_4;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  /* EXTI interrupt init*/
  HAL_NVIC_SetPriority(EXTI0_1_IRQn, 2, 0);
  HAL_NVIC_EnableIRQ(EXTI0_1_IRQn);
/* USER CODE BEGIN 4 */
void HAL_UART_RxCpltCallback(UART_HandleTypeDef*huart)
void HAL_UART_TxCpltCallback(UART_HandleTypeDef*huart)
__NOP();//test if we reach this position
void HAL_RTC_AlarmAEventCallback(RTC_HandleTypeDef *hrtc)
                         /* Turn LED3 on: Alarm generation */
                         //BSP_LED_On(LED3);
                    HAL_RTC_GetAlarm(hrtc,&sAlarm,RTC_ALARM_A,FORMAT_BIN);
                    if(sAlarm.AlarmTime.Seconds>58){
                    sAlarm.AlarmTime.Seconds=0;
                    }else{
                    sAlarm.AlarmTime.Seconds=sAlarm.AlarmTime.Seconds+1;
                    while(HAL_RTC_SetAlarm_IT(hrtc, &sAlarm, FORMAT_BIN)!=HAL_OK){}
     HAL_GPIO_TogglePin(GPIOC,GPIO_PIN_9);
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
