CubeMx generates unfunctionnal code with lib 1.5
Question asked by JulienD on Apr 24, 2016
Latest reply on Oct 25, 2016 by JulienD
Here's some code generated with cubeMx:
RCC_PeriphCLKInitTypeDef PeriphClkInit;
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_LSI
                                   | RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSICalibrationValue = 16;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL12;
RCC_OscInitStruct.PLL.PLLDIV = RCC_PLL_DIV3;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
                              | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_HSE_DIV8;
HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq() / 1000);
STM32Cube FW_L1 V1.5.0 lib changed some behaviour in HAL_RCCEx_PeriphCLKConfig function. It may return HAL_ERROR if HSE state is on.
This makes the above code return an error and not set the RTC.
I don't know exactly where's the bug but very basically I commented out the "return HAL_ERROR" and it does the job (maybe for my own use...).
I suppose this is a bug either in the lib either in cubeMx that does not call in the good order...
But maybe I did it wrong. In this case what ?
Julien
