Cummulative data loss in SD write
Question asked by Lyen.Rum on Mar 30, 2016
Latest reply on Apr 5, 2016 by Lyen.Rum
Hello all,
I am facing some data loss while SD card writing. My application needs to save timer count and accerelometer data in a 8KB buffer in every 10ms (Tim_9 interrupt) and when the buffer is full, it'll write to SD card. Tim_9 interrupt has higher priority (0) than SDIO (1).
It seems to loose 10~12 samples in every ~3s; What might be the reason? Is it missing data when processor executes SD write command ? I've tried double buffer: to store samples in another buffer when SD write executes. No improvement.
Is my approach wrong? I request your comment to fix it. Thank you.
int WriteIndex= 0;
char BufferSting[2][8192];
int main(void)
memset(&fs32, 0, sizeof(FATFS));   // SD card initialization
res = f_mount(0, &fs32);
memset(&fil, 0, sizeof(FIL));
res=f_open(&fil, filename, FA_OPEN_ALWAYS | FA_WRITE);
while(1)
PWR_EnterSleepMode(PWR_Regulator_ON, PWR_SLEEPEntry_WFI);
if(sample_flag == 1)  // 10ms interrupt from Timer 9
Acc_GetXYZ_Data16(&x,&y,&z); // Accerelometer data.
if(WriteIndex >= 8192)  // Buffer full
    f_lseek(&fil, fil.fsize);
    f_write(&fil, BufferSting[bf], strlen(BufferSting[bf]), &BytesWritten);  // SD card writing
    f_sync(&fil);
WriteIndex=0;
if (bf==0) bf=1;   // alternative buffer selection
else bf=0;
WriteIndex += sprintf(&BufferSting[bf][WriteIndex],"%d\t%d\t%d\t%d\r\n",CNT32,x,y,z);
else
sample_flag = 0;
void TIM9_IRQHandler(void)
if (TIM_GetITStatus(TIM9, TIM_IT_Update) != RESET)
CNT32= TIM5->CNT;  // 32-bit count
TIM5->CNT = 0;
TIM_ClearITPendingBit(TIM9, TIM_IT_Update);
sample_flag = 1;
