SDIO initialization
Question asked by aras.tolga on Mar 14, 2016
Latest reply on Mar 17, 2016 by aras.tolga
Hello Everybody
I'm trying to communicate with an SD-Card over SDIO but I even can't initialize it. I have the Nucleo-F446RE Board.
I am using the STM32CubeMX Software for the Initilization but I think, that I am missing something.
Here is the code that I have. I hope someone can help me.
main.c
#include "stm32f4xx_hal.h"
SD_HandleTypeDef hsd;
HAL_SD_CardInfoTypedef SDCardInfo;
DMA_HandleTypeDef hdma_sdio_tx;
UART_HandleTypeDef huart2;
DMA_HandleTypeDef hdma_usart2_tx;
static void MX_DMA_Init(void);
static void MX_USART2_UART_Init(void);
static   HAL_SD_ErrorTypedef MX_SDIO_SD_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
    HAL_SD_ErrorTypedef error;
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_USART2_UART_Init();
  error = MX_SDIO_SD_Init();
  /* USER CODE BEGIN 2 */
  wait(50);
  error = HAL_SD_Get_CardInfo(&hsd, &SDCardInfo);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  char buffer[] = "abcdefghijklmnopqrstuvwxyz";
  char rxbuffer[512];
  int i=0;
  while(i<512){
      rxbuffer[i]='a';
      i++;
  error = HAL_SD_WriteBlocks(&hsd,&buffer, 0x0, 512,1);
  error = HAL_SD_ReadBlocks(&hsd,(uint32_t) &rxbuffer, 0x0, 512,1);
  error = HAL_SD_CheckReadOperation(&hsd, 100);
//  HAL_SD_ReadBlocks(&hsd,&rxbuffer, 0x0, 512,1);
  USART2->CR3 |= USART_CR3_DMAT;
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
      HAL_DMA_Start(&hdma_usart2_tx, (uint32_t) &rxbuffer, &(USART2->DR),512);
      HAL_DMA_Start(&hdma_usart2_tx, (uint32_t) &error, &(USART2->DR),1);
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
  __PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 72;
  RCC_OscInitStruct.PLL.PLLQ = 3;
  RCC_OscInitStruct.PLL.PLLR = 2;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2);
  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_SDIO|RCC_PERIPHCLK_CK48;
  PeriphClkInitStruct.Clk48ClockSelection = RCC_CK48CLKSOURCE_PLLQ;
  PeriphClkInitStruct.SdioClockSelection = RCC_SDIOCLKSOURCE_CK48;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
/* SDIO init function */
  hsd.Instance = SDIO;
  hsd.Init.ClockEdge = SDIO_CLOCK_EDGE_RISING;
  hsd.Init.ClockBypass = SDIO_CLOCK_BYPASS_DISABLE;
  hsd.Init.ClockPowerSave = SDIO_CLOCK_POWER_SAVE_DISABLE;
  hsd.Init.BusWide = SDIO_BUS_WIDE_1B;
  hsd.Init.HardwareFlowControl = SDIO_HARDWARE_FLOW_CONTROL_DISABLE;
  hsd.Init.ClockDiv = 120;
  return HAL_SD_Init(&hsd, &SDCardInfo);
/* USART2 init function */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  HAL_UART_Init(&huart2);
  * Enable DMA controller clock
  __DMA1_CLK_ENABLE();
  __DMA2_CLK_ENABLE();
  /* DMA interrupt init */
  HAL_NVIC_SetPriority(DMA1_Stream6_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Stream6_IRQn);
  HAL_NVIC_SetPriority(DMA2_Stream3_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA2_Stream3_IRQn);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  /* GPIO Ports Clock Enable */
  __GPIOC_CLK_ENABLE();
  __GPIOH_CLK_ENABLE();
  __GPIOA_CLK_ENABLE();
  __GPIOB_CLK_ENABLE();
  __GPIOD_CLK_ENABLE();
  /*Configure GPIO pin : B1_Pin */
  GPIO_InitStruct.Pin = B1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : LD2_Pin */
  GPIO_InitStruct.Pin = LD2_Pin;
  GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
  HAL_GPIO_Init(LD2_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_RESET);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
stm32f4xx_hal_msp.c
/**tttttttttt
  * File Name          : stm32f4xx_hal_msp.c
  * Description        : This file provides code for the MSP Initialization
  *                      and de-Initialization codes.
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
extern DMA_HandleTypeDef hdma_sdio_tx;
extern DMA_HandleTypeDef hdma_usart2_tx;
  * Initializes the Global MSP.
void HAL_MspInit(void)
  /* USER CODE BEGIN MspInit 0 */
  /* USER CODE END MspInit 0 */
  HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_0);
  /* System interrupt init*/
  /* USER CODE BEGIN MspInit 1 */
  /* USER CODE END MspInit 1 */
void HAL_SD_MspInit(SD_HandleTypeDef* hsd)
  if(hsd->Instance==SDIO)
  /* USER CODE BEGIN SDIO_MspInit 0 */
  /* USER CODE END SDIO_MspInit 0 */
    /* Peripheral clock enable */
    __SDIO_CLK_ENABLE();
    /**SDIO GPIO Configuration
    PB2     ------> SDIO_CK
    PC8     ------> SDIO_D0
    PD2     ------> SDIO_CMD
    GPIO_InitStruct.Pin = GPIO_PIN_2;
    GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF12_SDIO;
    GPIO_InitStruct.Pin = GPIO_PIN_8;
    HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
    /* Peripheral DMA init*/
    hdma_sdio_tx.Instance = DMA2_Stream3;
    hdma_sdio_tx.Init.Channel = DMA_CHANNEL_4;
    hdma_sdio_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
    hdma_sdio_tx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_sdio_tx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_sdio_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
    hdma_sdio_tx.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
    hdma_sdio_tx.Init.Mode = DMA_PFCTRL;
    hdma_sdio_tx.Init.Priority = DMA_PRIORITY_LOW;
    hdma_sdio_tx.Init.FIFOMode = DMA_FIFOMODE_ENABLE;
    hdma_sdio_tx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;
    hdma_sdio_tx.Init.MemBurst = DMA_MBURST_INC4;
    hdma_sdio_tx.Init.PeriphBurst = DMA_PBURST_INC4;
    HAL_DMA_Init(&hdma_sdio_tx);
    __HAL_LINKDMA(hsd,hdmatx,hdma_sdio_tx);
  /* USER CODE BEGIN SDIO_MspInit 1 */
  /* USER CODE END SDIO_MspInit 1 */
void HAL_SD_MspDeInit(SD_HandleTypeDef* hsd)
  /* USER CODE BEGIN SDIO_MspDeInit 0 */
  /* USER CODE END SDIO_MspDeInit 0 */
    /* Peripheral clock disable */
    __SDIO_CLK_DISABLE();
    PB2     ------> SDIO_CK
    PC8     ------> SDIO_D0
    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_2);
    HAL_GPIO_DeInit(GPIOC, GPIO_PIN_8);
    HAL_GPIO_DeInit(GPIOD, GPIO_PIN_2);
    /* Peripheral DMA DeInit*/
    HAL_DMA_DeInit(hsd->hdmatx);
  /* USER CODE BEGIN SDIO_MspDeInit 1 */
  /* USER CODE END SDIO_MspDeInit 1 */
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  if(huart->Instance==USART2)
  /* USER CODE BEGIN USART2_MspInit 0 */
  /* USER CODE END USART2_MspInit 0 */
    __USART2_CLK_ENABLE();
    /**USART2 GPIO Configuration
    PA2     ------> USART2_TX
    PA3     ------> USART2_RX
    GPIO_InitStruct.Pin = USART_TX_Pin|USART_RX_Pin;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
    hdma_usart2_tx.Instance = DMA1_Stream6;
    hdma_usart2_tx.Init.Channel = DMA_CHANNEL_4;
    hdma_usart2_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
    hdma_usart2_tx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_usart2_tx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_usart2_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_usart2_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_usart2_tx.Init.Mode = DMA_NORMAL;
    hdma_usart2_tx.Init.Priority = DMA_PRIORITY_LOW;
    hdma_usart2_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    HAL_DMA_Init(&hdma_usart2_tx);
    __HAL_LINKDMA(huart,hdmatx,hdma_usart2_tx);
  /* USER CODE BEGIN USART2_MspInit 1 */
  /* USER CODE END USART2_MspInit 1 */
void HAL_UART_MspDeInit(UART_HandleTypeDef* huart)
  /* USER CODE BEGIN USART2_MspDeInit 0 */
  /* USER CODE END USART2_MspDeInit 0 */
    __USART2_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOA, USART_TX_Pin|USART_RX_Pin);
    HAL_DMA_DeInit(huart->hdmatx);
  /* USER CODE BEGIN USART2_MspDeInit 1 */
  /* USER CODE END USART2_MspDeInit 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
