F1 can hal_can_state always 0x22
Question asked by Bartocha.Mateusz.001 on Mar 11, 2016
Latest reply on Mar 13, 2016 by Bartocha.Mateusz.001
Hi!
I get working can in normal mode on two boards with F103:
* normal mode and I can see frames on scope
But...
I connect both of them together and I couldn't see Rx frames hal_can_state was always busy.
Board1 code - the one on which I was looking for frames:
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f1xx_hal.h"
/* USER CODE END Includes */
CAN_HandleTypeDef hcan;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_CAN_Init(void);
/* USER CODE BEGIN PFP */
static void Error_Handler(void);
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_CAN_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
    hcan.pTxMsg->Data[0] = 0xAD;
    hcan.pTxMsg->Data[1] = 0xAD;
    /* push button variable */
    int PB_State = 0;
  while (1)
  /* USER CODE END WHILE */
        /* if pushed switch state */
        if(HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_8)==0)
            if(PB_State==0)
                PB_State=1;
            }else
                PB_State=0;
        /* if state high start transmit */
        if(PB_State==1)
            HAL_CAN_Transmit(&hcan, 50);
            HAL_Delay(50);
        if(HAL_CAN_Receive_IT(&hcan, CAN_FIFO0) != HAL_OK)
        else
            /* if frame received toggle LED1 pin */
            HAL_GPIO_TogglePin(GPIOF, GPIO_PIN_6);
            if(hcan.pRxMsg->Data[0] == 0xAA)
                /* if correct data[0] toggle LED2 pin */
                HAL_GPIO_TogglePin(GPIOF, GPIO_PIN_7);
        HAL_Delay(500);
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_OscInitStruct.HSICalibrationValue = 16;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0);
/* CAN init function */
    static CanTxMsgTypeDef TxMess;
    static CanRxMsgTypeDef RxMess;
    hcan.pTxMsg = &TxMess;
    hcan.pRxMsg = &RxMess;
  hcan.Instance = CAN1;
  hcan.Init.Prescaler = 2;
  hcan.Init.Mode = CAN_MODE_NORMAL;
  hcan.Init.SJW = CAN_SJW_1TQ;
  hcan.Init.BS1 = CAN_BS1_6TQ;
  hcan.Init.BS2 = CAN_BS2_8TQ;
  hcan.Init.TTCM = DISABLE;
  hcan.Init.ABOM = DISABLE;
  hcan.Init.AWUM = DISABLE;
  hcan.Init.NART = DISABLE;
  hcan.Init.RFLM = DISABLE;
  hcan.Init.TXFP = DISABLE;
  if(HAL_CAN_Init(&hcan) != HAL_OK)
        Error_Handler();
    /** Frame config */
  hcan.pTxMsg->StdId = 0x321;
  hcan.pTxMsg->ExtId = 0x01;
  hcan.pTxMsg->RTR = CAN_RTR_DATA;
  hcan.pTxMsg->IDE = CAN_ID_STD;
  hcan.pTxMsg->DLC = 2;
/** Pinout Configuration
  /* GPIO Ports Clock Enable */
  __GPIOF_CLK_ENABLE();
  __GPIOA_CLK_ENABLE();
  __GPIOB_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOF, LED1_Pin|LED2_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pins : LED1_Pin LED2_Pin */
  GPIO_InitStruct.Pin = LED1_Pin|LED2_Pin;
  GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
  HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  /*Configure GPIO pin : USER_PB1_Pin */
  GPIO_InitStruct.Pin = USER_PB1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  HAL_GPIO_Init(USER_PB1_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  while (1)
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Board 2 - always transmit - code
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  MX_CAN_Init();
  /* Infinite loop */
    hcan.pTxMsg->Data[0] = 0xAA;
  while (1)
        if(HAL_CAN_Transmit(&hcan, 50) != HAL_OK)
        HAL_Delay(1000);
  HAL_CAN_Init(&hcan);
    if (HAL_CAN_Init(&hcan) != HAL_OK)
        while(1);
  * @param  None
  * @retval None
  while (1)
   * @retval None
#endif
I took decision to test it with loopback mode on first board, and still the same - hal_can_status always 0x22 - rx busy. Even if I forced before receive function to set status to ready I coulnd't see my frames on both normal and loopback mode.
Any idea what I did wrong ?
