Transfer File from terminal to STM32 Flash via UART over DMA
Question asked by foujanet.guillaume on Mar 3, 2016
Latest reply on Mar 3, 2016 by Clive One
Hi!
I would like to know if it's possible to transfer a file from a PC(with hyper terminal),  to the MCU' Flash, with the UART over DMA.
I use a stm32l151xc. , the file to transfert is moreorless 100kB.
I check the trasnfert to RAM with a file of 10kB, it's correct.
With the Flash as destination of the DMA, it's not working.
I try Byte and word alignment.
I am able to write the FLASH manually. but not with the DMA.
I have created a user_section into FLASH to play with.
Do you know if it's technically possible?(timing Flash)
thanks
PS: maybe use X/Y/Z Modem is a better solution. What are you think about that?
