X-CUBE-CRYPTOLIB(GCC) on STM32F207: AES incorrect encrypt/decrypt
Question asked by molnar.daniel on Feb 16, 2016
Latest reply on Feb 18, 2016 by molnar.daniel
Hi! I'm using the X-CUBE-CRYPTOLIB (AES-256-ECB) on the STM3220 devboard using System Workbench (GCC) with no luck.
I set the config.h file (tried every permutation nearly), my project compiles successfully, and I am able to run my test program in which I want to encrypt an array then decrypt it immediately.
Upon doing so I don't get the original plaintext back (some mumbo-jumbo only). I think I might be missing something small but significant (I used the non X- version in Keil before, and it had a Crypto_Deinit() function which this X- version doesn't have).
I pasted my sample code below, can anyone help me?
uint8_t key_enc_256[CRL_AES256_KEY]= AES256_KEY;
uint8_t iv[CRL_AES_BLOCK]= AES256_IV;
AESECBctx_stt AESctx_enc; /* The AES context */
AESECBctx_stt AESctx_dec; /* The AES context */
uint8_t test_plain[256];
uint8_t test_cypher[256];
 * \brief  Initializes AES encrypt/decrypt contexts
 * \param  None
 * \retval None
void AES_init()
    uint8_t retval;
    int32_t i;
    /* Initialize Context Flag with default value */
    AESctx_enc.mFlags = E_SK_DEFAULT;
    /* Set Iv size to 16 NOT USED IN ECB*/
    AESctx_enc.mIvSize=32;
    /* Set key size to 32 */
    AESctx_enc.mKeySize=CRL_AES256_KEY;
    AESctx_dec.mFlags = E_SK_DEFAULT;
    AESctx_dec.mIvSize=32;
    AESctx_dec.mKeySize=CRL_AES256_KEY;
    retval = AES_ECB_Encrypt_Init(&AESctx_enc, key_enc_256, iv);
    if(retval != AES_SUCCESS)
    { while(1); }
    retval = AES_ECB_Decrypt_Init(&AESctx_dec, key_enc_256, iv);
    { while(1); }
    for(i = 0; i < 256; i++)
        test_plain[i] = 0;
    retval = AES_ECB_Encrypt_Append(&AESctx_enc,test_plain,256,test_cypher,&i);
    { while(1); }
    retval = AES_ECB_Decrypt_Append(&AESctx_dec,test_cypher,256,test_plain,&i);
    { while(1); }
Kind regards,
Daniel
