Tim1 & Tim15 in Assembly
Question asked by Johnson.Mark.001 on Jan 20, 2016
Latest reply on Jan 20, 2016 by waclawek.jan
My application requires to input capture a pulse to trigger TIM1 & TIM15. The trigger pulse is present on both input capture pins and channels. Both timers are to turn on at the same time but have different counts to be outputted on different pins. I was able to get TIM1 working but not TIM15. The code is below. Can anyone identify where the problem resides?
Main.c Function
void configureGPIO (void){
     RCC->APB1ENR |= RCC_APB1ENR_TIM3EN; // Enable TIM3 clk
     RCC->APB2ENR |= RCC_APB2ENR_TIM1EN | RCC_APB2ENR_TIM15EN; //      Enable TIM1,15 clk
     RCC->AHBENR |= RCC_AHBENR_GPIOAEN | RCC_AHBENR_GPIOBEN |      RCC_AHBENR_GPIOCEN | RCC_AHBENR_GPIODEN;  // Enable peripheral      ckls GPIO A,B,C,D
     GPIOA->AFR[0] |= 0x02 << (2*4); // Select TIM15_CH1 on PA2 by enabling AF0      on GPIOA AFRL register
     GPIOA->AFR[0] |= 0x02 << (3*4); // Select TIM15_CH2 on PA3 by enabling AF0      on GPIOA AFRL register
     GPIOA->AFR[1] |= 0x02 << ((9-8)*4); // Select TIM1_CH2 on PA9 by enabling      AF2 on GPIOA AFRH register
     GPIOA->AFR[1] |= 0x02 << ((10-8)*4); // Select TIM1_CH3 on PA10 by enabling      AF2 on GPIOA AFRH register
     GPIOA->MODER = (GPIOA->MODER & ~(GPIO_MODER_MODER2 |      GPIO_MODER_MODER3 | GPIO_MODER_MODER9 |      GPIO_MODER_MODER10)) | (GPIO_MODER_MODER2_1  |      GPIO_MODER_MODER3_1 | GPIO_MODER_MODER9_1 |      GPIO_MODER_MODER10_1); // Alt Function PA2,3,9,10
;Main.s Function
;TIM1 CONFIG
     LDR R1,=0x40012C00 ;MOVE TIM1_CR1 ADDRESS TO R1
     LDR R0,=2_0000000010001000 ;MOVE TIM1_CR1 DATA TO R0
     STR R0,[R1] ;MOVE TIM1_CR1 DATA TO TIM1_CR1 LOCATION
     LDR R1,=0x40012C08 ;MOVE TIM1_SMCR ADDRESS TO R1
     LDR R0,=2_0000000001100110 ;MOVE TIM1_SMCR DATA TO R0
     STR R0,[R1] ;MOVE TIM1_SMCR DATA TO TIM1_SMCR LOC
     LDR R1,=0x40012C18 ;MOVE TIM1_CCMR1 ADDRESS TO R1
     LDR R0,=2_0000000100000000 ;MOVE TIM1_CCMR1 DATA TO R0
     STR R0,[R1] ;MOVE TIM1_CCMR1 LOCATION
     LDR R1,=0x40012C1C ;MOVE TIM1_CCMR2 ADDRESS TO R1
     LDR R0,=2_0000000001110000 ;MOVE TIM1_CCMR2 DATA TO R0
     STR R0,[R1] ;MOVE TIM1_CCMR2 DATA TIM1_CCMR2 LOC
     LDR R1,=0X40012C20 ;MOVE TIM1_CCER ADDRESS TO R1
     LDR R0,=2_0000101100000000 ;MOVE TIM1_CCER DATA TO R0
     STR R0,[R1] ;MOVE TIM1_CCER DATA TO TIM1_CCER LOC
     LDR R1,=0x40012C2C ;MOVE TIM1_ARR ADDRESS TO R1
     LDR R0,=4000 ;LOAD AUTO-RELOAD WITH 100uS
     STR R0,[R1] ;MOVE TIM_1ARR DATA TO TIM1-ARR LOCATION
     LDR R1,=0x40012C44 ;Move TIM1_BDTR ADDRESS TO R1
     LDR R0,=2_1000000000000000 ;MOVE TIM1_CR1 DATA
     STR R0,[R1] ;MOVE TIM1_BDTR DATA TO LOC
;TIM15 CONFIG
     LDR R1,=0x40014000 ;MOVE TIM15_CR1 ADDRESS TO R1
     LDR R0,=2_0010001000 ;OPM = 1, ARPE = 1, CKD = 00
     STR R0,[R1] ;MOVE DATA TO TIM15_CR1 REGISTER
     LDR R1,=0x40014004; MOVE TIM15_CR2 ADDRESS TO R1
     LDR R0,=2_00001010000 ;MMS = 101
     STR R0,[R1]; MMS = 101 PUTS OC2REF ON TRIG0
     LDR R1,=0x40014008; MOVE TIM15_SMCR ADDRESS TO R1
     LDR R0,=2_01010110 ;TS = 101, SMS = 110
     STR R0,[R1] ;TS = 101 (TI1FP1), SMS = 110 (TRIGGER MODE)
     LDR R1,=0x40014018 ;MOVE TIM15_CCMR1 ADDRESS TO R1
     LDR R0,=2_0001000000000001 ;CC1S = 01 (CHANNEL 1 INPUT)
     STR R0,[R1] ;OC2M = 001 (OC2REF IS COMPARE ACTIVE)
     LDR R1,=0x40014038 ;MOVE TIM15_CCR2 ADDRESS TO R1
     LDR R0,=0x438 ;DECIMAL 1080
     STR R0,[R1] ;1080*25nS = 27uS DELAY TO START SMP
     LDR R1,=0X40014020 ;MOVE TIM15_CCER ADDRESS TO R1
     LDR R0,=2_0000000010110000 ;MOVE TIM15_CCER DATA TO R0
     STR R0,[R1] ;MOVE TIM15_CCER DATA TO TIM15_CCER LOC
     LDR R1,=0x4001402C ;MOVE TIM15_ARR ADDRESS TO R1
     LDR R0,=0xFA0 ;DECIMAL 4000 = 100uS
     STR R0,[R1] ;TIMEOUT PERIOD WHEN TIM15 RESETS
     LDR R1,=0x40014044 ;Move TIM15_BDTR ADDRESS TO R1
     LDR R0,=2_1000000000000000; MOVE TIM15_CR1 DATA
     STR R0,[R1] ;MOVE TIM15_BDTR DATA TO LOCATION
