STM32F0XX RTC calendar can't be configured
Question asked by jeremy_cis on Jan 14, 2016
Latest reply on Mar 31, 2016 by FTITI.Walid
When system boots up, RTC is initialized and could be configured with success any time, but any calendar configuration will fail after a system reset. After a system reset the RTC_EnterInitMode() function always return HAL_TIMEOUT, causing HAL_RTC_SetTime returns HAL_ERROR. I'm using ST32F042F6P6, STM32CubeMX v4.12.0 and System Workbench for STM32 v1.6.0.201512071631. I appreciate if anyone can help me. The functions utilized are show below:
  * @brief  Set RTC current time.
  * @param  hrtc: RTC handle
  * @param  sTime: Pointer to Time structure
  * @param  Format: Specifies the format of the entered parameters.
  *          This parameter can be one of the following values:
  *            @arg RTC_FORMAT_BIN: Binary data format
  *            @arg RTC_FORMAT_BCD: BCD data format
  * @retval HAL status
HAL_StatusTypeDef HAL_RTC_SetTime(RTC_HandleTypeDef *hrtc, RTC_TimeTypeDef *sTime, uint32_t Format)</span></div></div>
  uint32_t tmpreg = 0;
 /* Check the parameters */
  assert_param(IS_RTC_FORMAT(Format));</div>
  assert_param(IS_RTC_DAYLIGHT_SAVING(sTime->DayLightSaving));</div>
  assert_param(IS_RTC_STORE_OPERATION(sTime->StoreOperation));</div>
  /* Process Locked */
  __HAL_LOCK(hrtc);
  hrtc->State = HAL_RTC_STATE_BUSY;
  if(Format == RTC_FORMAT_BIN)
    if((hrtc->Instance->CR & RTC_CR_FMT) != (uint32_t)RESET)
      assert_param(IS_RTC_HOUR12(sTime->Hours));</div>
      assert_param(IS_RTC_HOURFORMAT12(sTime->TimeFormat));</div>
    else
      sTime->TimeFormat = 0x00;
      assert_param(IS_RTC_HOUR24(sTime->Hours));</div>
    assert_param(IS_RTC_MINUTES(sTime->Minutes));</div>
    assert_param(IS_RTC_SECONDS(sTime->Seconds));</div>
    tmpreg = (uint32_t)(((uint32_t)RTC_ByteToBcd2(sTime->Hours) << 16) | \</div>
                        ((uint32_t)RTC_ByteToBcd2(sTime->Minutes) << 8) | \</div>
                        ((uint32_t)RTC_ByteToBcd2(sTime->Seconds)) | \</div>
                        (((uint32_t)sTime->TimeFormat) << 16));
  else
      tmpreg = RTC_Bcd2ToByte(sTime->Hours);
      assert_param(IS_RTC_HOUR12(tmpreg));</div>
      assert_param(IS_RTC_HOURFORMAT12(sTime->TimeFormat)); </div>
    else
      assert_param(IS_RTC_HOUR24(RTC_Bcd2ToByte(sTime->Hours)));</div>
    assert_param(IS_RTC_MINUTES(RTC_Bcd2ToByte(sTime->Minutes)));</div>
    assert_param(IS_RTC_SECONDS(RTC_Bcd2ToByte(sTime->Seconds)));</div>
    tmpreg = (((uint32_t)(sTime->Hours) << 16) | \
              ((uint32_t)(sTime->Minutes) << 8) | \
              ((uint32_t)sTime->Seconds) | \
              ((uint32_t)(sTime->TimeFormat) << 16));
  /* Disable the write protection for RTC registers */
  __HAL_RTC_WRITEPROTECTION_DISABLE(hrtc);</span></div>
  /* Set Initialization mode */
  if(RTC_EnterInitMode(hrtc) != HAL_OK)
    /* Enable the write protection for RTC registers */
    __HAL_RTC_WRITEPROTECTION_ENABLE(hrtc); </span></div>
    /* Set RTC state */
    hrtc->State = HAL_RTC_STATE_ERROR;
    /* Process Unlocked */
    __HAL_UNLOCK(hrtc);
    return HAL_ERROR;
  else
    /* Set the RTC_TR register */
    hrtc->Instance->TR = (uint32_t)(tmpreg & RTC_TR_RESERVED_MASK);
    /* Clear the bits to be configured */
    hrtc->Instance->CR &= ((uint32_t)~RTC_CR_BCK);
    /* Configure the RTC_CR register */
    hrtc->Instance->CR |= (uint32_t)(sTime->DayLightSaving | sTime->StoreOperation);</div>
    /* Exit Initialization mode */
    hrtc->Instance->ISR &= ((uint32_t)~RTC_ISR_INIT);
    /* If  CR_BYPSHAD bit = 0, wait for synchro else this check is not needed */
    if((hrtc->Instance->CR & RTC_CR_BYPSHAD) == RESET)
      if(HAL_RTC_WaitForSynchro(hrtc) != HAL_OK)</div>
        __HAL_UNLOCK(hrtc);
        return HAL_ERROR;
    __HAL_RTC_WRITEPROTECTION_ENABLE(hrtc);</span></div>
   hrtc->State = HAL_RTC_STATE_READY;
   __HAL_UNLOCK(hrtc);
   return HAL_OK;
//////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////</div>
  * @brief  Disable the write protection for RTC registers.
  * @param  __HANDLE__: specifies the RTC handle.
  * @retval None
#define __HAL_RTC_WRITEPROTECTION_DISABLE(__HANDLE__) </span>            \</div>
                        do{                                       \
                            (__HANDLE__)->Instance->WPR = 0xCA;   \
                            (__HANDLE__)->Instance->WPR = 0x53;   \
                          } while(0)
  * @brief  Enable the write protection for RTC registers.
  * @retval None
#define __HAL_RTC_WRITEPROTECTION_ENABLE(__HANDLE__) </span>             \</div>
                        do{                                       \
                            (__HANDLE__)->Instance->WPR = 0xFF;   \
                          } while(0)
  * @brief  Enter the RTC Initialization mode.
  * @note   The RTC Initialization mode is write protected, use the
  *         __HAL_RTC_WRITEPROTECTION_DISABLE() before calling this function.</div>
HAL_StatusTypeDef RTC_EnterInitMode(RTC_HandleTypeDef* hrtc)</span></div>
  uint32_t tickstart = 0;
  /* Check if the Initialization mode is set */
  if((hrtc->Instance->ISR & RTC_ISR_INITF) == (uint32_t)RESET)
    /* Set the Initialization mode */
    hrtc->Instance->ISR = (uint32_t)RTC_INIT_MASK;
    tickstart = HAL_GetTick();
    /* Wait till RTC is in INIT state and if Time out is reached exit */
    while((hrtc->Instance->ISR & RTC_ISR_INITF) == (uint32_t)RESET)
      if((HAL_GetTick()-tickstart) > RTC_TIMEOUT_VALUE)
        return HAL_TIMEOUT;
  return HAL_OK;
