I2C HAL_I2C_Master_Receive doesn´t work
Question asked by wild.andreas on Jan 8, 2016
Latest reply on Mar 11, 2016 by Amel N
Hello to all,
I use STM32F2xx with Cube Version V1.1.1
The touch controller from the display is connected via I2C.
In STPerLIb everything works fine.
When I read the coordinates from the touch controller I use HAL_I2C_Master_Receive in order to receive 8 Bytes.
Here is the original HAL_I2C_Master_Receive function where I will comment the possible faults:
HAL_StatusTypeDef HAL_I2C_Master_Receive(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout)
  if(hi2c->State == HAL_I2C_STATE_READY)
    if((pData == NULL) || (Size == 0))
      return  HAL_ERROR;
    /* Wait until BUSY flag is reset */
    if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BUSY, SET, I2C_TIMEOUT_BUSY_FLAG) != HAL_OK)
      return HAL_BUSY;
    /* Process Locked */
    __HAL_LOCK(hi2c);
    /* Disable Pos */
    hi2c->Instance->CR1 &= ~I2C_CR1_POS;
    hi2c->State = HAL_I2C_STATE_BUSY_RX;
    hi2c->ErrorCode = HAL_I2C_ERROR_NONE;
    /* Send Slave Address */
    if(I2C_MasterRequestRead(hi2c, DevAddress, Timeout) != HAL_OK)
      if(hi2c->ErrorCode == HAL_I2C_ERROR_AF)
        /* Process Unlocked */
        __HAL_UNLOCK(hi2c);
        return HAL_ERROR;
      else
        __HAL_UNLOCK(hi2c);
        return HAL_TIMEOUT;
    if(Size == 1)
      /* Disable Acknowledge */
      hi2c->Instance->CR1 &= ~I2C_CR1_ACK;
      /* Clear ADDR flag */
      __HAL_I2C_CLEAR_ADDRFLAG(hi2c);
      /* Generate Stop */
      hi2c->Instance->CR1 |= I2C_CR1_STOP;
    else if(Size == 2)
      /* Enable Pos */
      hi2c->Instance->CR1 |= I2C_CR1_POS;
    else
    {  //my size is 8 Bytes, so Acknowledge is enabled here: correct
      /* Enable Acknowledge */
      hi2c->Instance->CR1 |= I2C_CR1_ACK;
    while(Size > 0)
      if(Size <= 3)
        /* One byte */
        if(Size == 1)
          /* Wait until RXNE flag is set */
          if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_RXNE, RESET, Timeout) != HAL_OK)
            return HAL_TIMEOUT;
          /* Read data from DR */
          (*pData++) = hi2c->Instance->DR;
          Size--;
        /* Two bytes */
        else if(Size == 2)
          /* Wait until BTF flag is set */
          if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BTF, RESET, Timeout) != HAL_OK)
            return HAL_TIMEOUT;
          /* Generate Stop */
          Size--;
          Size--;
        /* 3 Last bytes */
        else
            return HAL_TIMEOUT;
          /* Disable Acknowledge */ //after reception of 5 Bytes for the last remaining 3 bytes
                //the ackknowledge is disabled. This is wrong because the last bytes also need
                //ackknowledge. In this case my touch controller hangs and does not release the
                //interupt pin!!
          Size--;
            return HAL_TIMEOUT;
          /* Generate Stop */ //The stop condition is generated before reading the second
         //last byte. When I do this the touch controller hangs
          Size--;
          Size--;
      else
          return HAL_TIMEOUT;
        Size--;
        if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_BTF) == SET)
          Size--;
    hi2c->State = HAL_I2C_STATE_READY;
    __HAL_UNLOCK(hi2c);
    return HAL_OK;
  else
    return HAL_BUSY;
And here is the modified HAL_I2C_Master_Receive() function which runs ok.
I marked my changes in RED.
      return  HAL_ERROR;
      return HAL_BUSY;
    __HAL_LOCK(hi2c);
    /* Disable Pos */
        __HAL_UNLOCK(hi2c);
        return HAL_ERROR;
      else
        __HAL_UNLOCK(hi2c);
        return HAL_TIMEOUT;
    if(Size == 1)
      /* Generate Stop */
    else if(Size == 2)
      /* Enable Pos */
    else
    while(Size > 0)
      if(Size <= 3)
        /* One byte */
        if(Size == 1)
            return HAL_TIMEOUT;
          Size--;
        /* Two bytes */
        else if(Size == 2)
            return HAL_TIMEOUT;
          /* Generate Stop */
          Size--;
          Size--;
        /* 3 Last bytes */
        else
            return HAL_TIMEOUT;
          /* Disable Acknowledge */  //no disable of ACK because there are 3 bytes left!!
        //  hi2c->Instance->CR1 &= ~I2C_CR1_ACK;
          Size--;
            return HAL_TIMEOUT;
           /* Read data from DR */ //read the second last byte BEFORE setting stop condition!!
          Size--;
          /* Generate Stop */
          (*pData++) = hi2c->Instance->DR; //now we read last byte
          Size--;
      else
          return HAL_TIMEOUT;
        Size--;
          Size--;
    __HAL_UNLOCK(hi2c);
    return HAL_OK;
  else
    return HAL_BUSY;
I am happy to get any comments about this issue.
Thanks a lot
Andy
