Spi with dma
Question asked by emb_begin on Jan 7, 2016
Latest reply on Jan 8, 2016 by peacock.jack.003
the goal is to tranfer the data from memory to spi. The buffer values are 32 bit. and the spi data register is 16 bit. i made a configuration to take the 32 bit value and put it in fifo, then take 16 bit value from fifo and put it in spi data register.
the dma did not work. is there any problem with the configuration.. please help me
The configuration is below.
#define buffer_count 1200
uint32_t buffer[buffer_count];
void spi_dma2d_halfword(SPI_TypeDef* SPIx)
      DMA_InitStructure.DMA_MemoryInc =  DMA_MemoryInc_Enable;
      DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
      DMA_InitStructure.DMA_Priority = DMA_Priority_Low;
      DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable ;
      DMA_InitStructure.DMA_FIFOThreshold =  DMA_FIFOThreshold_1QuarterFull;
      DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_INC4 ;  //1 burst fo 4 beats
      DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
** memory data size   */
          DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
          DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
       /* Configure TX DMA */
          DMA_InitStructure.DMA_BufferSize = buffer_count ;       //buffer size
          DMA_InitStructure.DMA_PeripheralBaseAddr =(uint32_t)(&SPI6->DR);
          DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)(&outpuf_pfc) ;
          /**** channel and direction ***/
          DMA_InitStructure.DMA_Channel = DMA_Channel_1 ;
          DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral ;
          /*** initialize ***/
          DMA_Init(DMA2_Stream5, &DMA_InitStructure);
