FatFS append file only once opened
Question asked by Lukasz Przenioslo on Dec 10, 2015
Latest reply on Dec 10, 2015 by Lukasz Przenioslo
Hello there,
I have a logger application on a STM32F407 device. I am saving logs to sd card. Generally it works, but I would like to make the procedure a bit faster by opening the file only once at the begining of the program. The problem is when I do that, I dont get anything saved...
This is my "append to file" procedure:
static HAL_StatusTypeDef log_AppendFileSdCard(uint8_t* text, uint32_t length)
    FRESULT res;
    uint32_t bytesWritten = 0;
    if (FR_OK != f_open(&log_File, (const TCHAR*)logName, FA_WRITE))
        return HAL_ERROR;
    if (FR_OK != f_lseek(&log_File, f_size(&log_File)))
        return HAL_ERROR;
    res = f_write(&log_File, text, length, (void *)&bytesWritten);
    if((bytesWritten > 0) && (res == FR_OK))
        if (FR_OK != f_close(&log_File))
            return HAL_ERROR;
    else
        return HAL_ERROR;
    return HAL_OK;
If for example, I create the file and leave it opened, and remove the open/ close functions from my procedure:
    FRESULT res;
        return HAL_ERROR;
              // dont close
    else
        return HAL_ERROR;
    return HAL_OK;
There is nothing saved to the file, even though write doesnt return any error and the index of the file struct is incremented. What could be the case here, am I doing something wrong?
I would apreciate all help!
