General C question - volatile cast
Question asked by bonelli on Nov 30, 2015
Latest reply on Dec 1, 2015 by AvaTar
Using a lot of global variables modified into ISR sections, I use a lot the "volatile" keyword when needed.
volatile int foo;
int square(int din)
   return din*din;
result = square(foo); // Does not compile: cast error
Actually, this kind of C-code are not supported by IAR:
"int" type is not compatible with "volatile int" type.
The obvious solution is to do a cast:
result = square((int)foo); // Compile very well but absolutely boring!
With big projects, many structures and many functions with many parameters doing a cast for each parameter is very time-consuming and does not render the code very clear.
Is there a way to tell to the compiler: "Don't annoy me with volatile uncasted types!" ?
Thank you
