Why does L6480H driver register value reset to default
Question asked by liang.chris.001 on Apr 22, 2015
Latest reply on Apr 27, 2015 by liang.chris.001
Hi all,
I using L6480H drive stepper motor with 24V VS.
I have it working on L6480H eval board with my TI Tiva C eval board.
it can drive motor.
then I used same working firmware run on our customized board. it did not spin the motor and the L6480H register value reset after I send motion command such as Run, Move. I monitored STBY/RESET pin, it stays high all the time.
Also, i realized when I send motion command, I heard a very light click sound. I guess this is something cause the chip reset.
any clues?
Thanks in advance.
the following is the register value I wrote to the chip at the initialization stage.
/**************************** Speed Profile *********************************/
/* Register : ACC */
     /* X-Axis motor acceleration rate in step/s2, range 14.55 to 59590 steps/s2 */
#define L6480H_CONF_PARAM_ACC_X (2197.339)
     /* Y-Axis motor acceleration rate in step/s2, range 14.55 to 59590 steps/s2 */
#define L6480H_CONF_PARAM_ACC_Y (2401.066)
/* Register : DEC */
     /* X-Axis motor deceleration rate in step/s2, range 14.55 to 59590 steps/s2 */
#define L6480H_CONF_PARAM_DEC_X (2197.339)
     /* Y-Axis motor deceleration rate in step/s2, range 14.55 to 59590 steps/s2 */
#define L6480H_CONF_PARAM_DEC_Y (2401.066)
/* Register : MAX_SPEED */
     /* X-Axis motor maximum speed in step/s, range 15.25 to 15610 steps/s */
#define L6480H_CONF_PARAM_MAX_SPEED_X (503.54)
     /* Y-Axis motor maximum speed in step/s, range 15.25 to 15610 steps/s */
#define L6480H_CONF_PARAM_MAX_SPEED_Y (503.54)
/* Register : MIN_SPEED */
     /* Minimum speed in step/s, range 0 to 976.3 steps/s */
#define L6480H_CONF_PARAM_MIN_SPEED (0)
/* Register : FS_SPD */
     /* X-Axis motor full step speed in step/s, range 7.63 to 15625 steps/s */
#define L6480H_CONF_PARAM_FS_SPD_X (793.457)
     /* Y-Axis motor full step speed in step/s, range 7.63 to 15625 steps/s */
#define L6480H_CONF_PARAM_FS_SPD_Y (793.457)
/************************ Phase Current Control *****************************/
/* Register : KVAL_HOLD */
/* Hold duty cycle (torque) in %, range 0 to 99.6% */
#define L6480H_CONF_PARAM_KVAL_HOLD (16.02)
/* Register : KVAL_RUN */
/* Run duty cycle (torque) in %, range 0 to 99.6% */
#define L6480H_CONF_PARAM_KVAL_RUN (16.02)
/* Register : KVAL_ACC */
/* Acceleration duty cycle (torque) in %, range 0 to 99.6% */
#define L6480H_CONF_PARAM_KVAL_ACC (16.02)
/* Register : KVAL_DEC */
/* Deceleration duty cycle (torque) in %, range 0 to 99.6% */
#define L6480H_CONF_PARAM_KVAL_DEC (16.02)
/* Register : CONFIG - field : EN_VSCOMP */
/* Motor Supply Voltage Compensation enabling , enum L6480H_CONFIG_EN_VSCOMP_TypeDef */
#define L6480H_CONF_PARAM_VS_COMP (L6480H_CONFIG_VS_COMP_DISABLE)
/* Register : MIN_SPEED - field : LSPD_OPT */
/* Low speed optimization bit, enum L6480H_LSPD_OPT_TypeDef */
#define L6480H_CONF_PARAM_LSPD_BIT (L6480H_LSPD_OPT_OFF)
/* Register : K_THERM */
/* Thermal compensation param, range 1 to 1.46875 */
#define L6480H_CONF_PARAM_K_THERM (1)
/* Register : INT_SPEED */
/* Intersect speed settings for BEMF compensation in steps/s, range 0 to 3906 steps/s */
#define L6480H_CONF_PARAM_INT_SPD (61.512)
/* Register : ST_SLP */
/* BEMF start slope settings for BEMF compensation in % step/s, range 0 to 0.4% s/step */
#define L6480H_CONF_PARAM_ST_SLP (0.03815)
/* Register : FN_SLP_ACC */
/* BEMF final acc slope settings for BEMF compensation in % step/s, range 0 to 0.4% s/step  */
#define L6480H_CONF_PARAM_FN_SLP_ACC (0.06256)
/* Register : FN_SLP_DEC */
/* BEMF final dec slope settings for BEMF compensation in % step/s, range 0 to 0.4% s/step */
#define L6480H_CONF_PARAM_FN_SLP_DEC (0.06256)
/* Register : CONFIG - field : F_PWM_INT */
/* PWM Frequency Integer division, enum L6480H_CONFIG_F_PWM_INT_TypeDef */
#define L6480H_CONF_PARAM_PWM_DIV (L6480H_CONFIG_PWM_DIV_2)
/* Register : CONFIG - field : F_PWM_DEC */
/* PWM Frequency Integer Multiplier, enum L6480H_CONFIG_F_PWM_INT_TypeDef */
#define L6480H_CONF_PARAM_PWM_MUL (L6480H_CONFIG_PWM_MUL_1)
/******************************* Gate Driving **********************************/
/* Register : GATECFG1 - field : TBOOST */
     /* Duration of the overboost phase during gate turn-off via enum L6480H_TBOOST_TypeDef */
#define L6480H_CONF_PARAM_TBOOST     (L6480H_TBOOST_0ns)
/* Register : GATECFG1 - field : IGATE */
     /* Gate sink/source current via enum L6480H_IGATE_TypeDef */
//#define L6480H_CONF_PARAM_IGATE      (L6480H_IGATE_96mA)
#define L6480H_CONF_PARAM_IGATE      (L6480H_IGATE_16mA)
/* Register : GATECFG1 - field : TCC */
     /* Controlled current time via enum L6480H_TCC_TypeDef */
//#define L6480H_CONF_PARAM_TCC        (L6480H_TCC_125ns)
#define L6480H_CONF_PARAM_TCC        (L6480H_TCC_3125ns)
/* Register : GATECFG2 - field : TBLANK */
     /* Duration of the blanking time via enum L6480H_TBLANK_TypeDef */
//#define L6480H_CONF_PARAM_TBLANK     (L6480H_TBLANK_125ns)
#define L6480H_CONF_PARAM_TBLANK     (L6480H_TBLANK_375ns)
/* Register : GATECFG2 - field : TDT */
     /* Duration of the dead time via enum L6480H_TDT_TypeDef */
//#define L6480H_CONF_PARAM_TDT        (L6480H_TDT_125ns)
#define L6480H_CONF_PARAM_TDT        (L6480H_TDT_375ns)
/* Register : CONFIG - field : VCCVAL */
     /* VCC Val, enum L6480H_CONFIG_VCCVAL_TypeDef */
//#define L6480H_CONF_PARAM_VCCVAL (L6480H_CONFIG_VCCVAL_15V)
#define L6480H_CONF_PARAM_VCCVAL (L6480H_CONFIG_VCCVAL_7_5V)
/* Register : CONFIG - field : UVLOVAL */
     /* UVLO Threshold via L6480H_CONFIG_UVLOVAL_TypeDef */
#define L6480H_CONF_PARAM_UVLOVAL    (L6480H_CONFIG_UVLOVAL_HIGH)
/******************************* Others *************************************/
/* Register : OCD_TH */
     /* Overcurrent threshold settings via enum L6480H_OCD_TH_TypeDef*/
#define L6480H_CONF_PARAM_OCD_TH (L6480H_OCD_TH_1V)
/* Register : STALL_TH */
/* Stall threshold settings in mV, range 31.25mV to 1000mV */
#define L6480H_CONF_PARAM_STALL_TH (1000.00)
/* Register : ALARM_EN */
/* Alarm settings via bitmap enum L6480H_ALARM_EN_TypeDef */
#define L6480H_CONF_PARAM_ALARM_EN (L6480H_ALARM_EN_OVERCURRENT | \
                                             L6480H_ALARM_EN_THERMAL_SHUTDOWN | \
                                             L6480H_ALARM_EN_THERMAL_WARNING | \
                                             L6480H_ALARM_EN_UVLO | \
                                             L6480H_ALARM_EN_ADC_UVLO | \
                                             L6480H_ALARM_EN_STALL_DETECTION | \
                                             L6480H_ALARM_EN_SW_TURN_ON | \
                                             L6480H_ALARM_EN_WRONG_NPERF_CMD)
/* Register : STEP_MODE - field : STEP_MODE */
     /* Step mode settings via enum L6480H_STEP_SEL_TypeDef */
#define L6480H_CONF_PARAM_STEP_MODE (L6480H_STEP_SEL_1_128)
/* Register : STEP_MODE - Field : SYNC_MODE and SYNC_EN */
/* Synch. Mode settings via enum cSPIN_SYNC_SEL_TypeDef */
#define L6480H_CONF_PARAM_SYNC_MODE (L6480H_SYNC_SEL_DISABLED)
/* Register : GATECFG1 - field : WD_EN */
/* External clock watchdog, enum L6480H_WD_EN_TypeDef */
#define L6480H_CONF_PARAM_WD_EN (L6480H_WD_EN_DISABLE)
/* Register : CONFIG - field : OC_SD */
     /* Over current shutwdown enabling, enum L6480H_CONFIG_OC_SD_TypeDef */
#define L6480H_CONF_PARAM_OC_SD (L6480H_CONFIG_OC_SD_DISABLE)
/* Register : CONFIG - field : SW_MODE */
     /* External switch hard stop interrupt mode, enum L6480H_CONFIG_SW_MODE_TypeDef */
#define L6480H_CONF_PARAM_SW_MODE (L6480H_CONFIG_SW_HARD_STOP)
/* Register : CONFIG - field : OSC_CLK_SEL */
     /* Clock setting , enum L6480H_CONFIG_OSC_MGMT_TypeDef */
#define L6480H_CONF_PARAM_CLOCK_SETTING (L6480H_CONFIG_INT_16MHZ_OSCOUT_2MHZ)
