TJpgDec + DMA2D
Question asked by chuev.vladimir on Oct 6, 2015
Hi.
I'm trying to combine TJpgDec  and DMA2D.
However, the display shows white square.
UINT output_func(JDEC *jd, void *bitmap, JRECT *rect){
    static DMA2D_HandleTypeDef hdma2d_eval;
    WORD h = rect->right - rect->left + 1;
    WORD w = rect->bottom - rect->top + 1;
    /* Configure the DMA2D Mode, Color Mode and output offset */
    hdma2d_eval.Init.Mode = DMA2D_M2M_PFC;
    hdma2d_eval.Init.ColorMode = DMA2D_ARGB8888;
    hdma2d_eval.Init.OutputOffset = 0;
    /* Foreground Configuration */
    hdma2d_eval.LayerCfg[1].AlphaMode = DMA2D_NO_MODIF_ALPHA;
    hdma2d_eval.LayerCfg[1].InputAlpha = 0xFF;
    hdma2d_eval.LayerCfg[1].InputColorMode = CM_RGB888;
    hdma2d_eval.LayerCfg[1].InputOffset = 0;
    hdma2d_eval.Instance = DMA2D;
    /* DMA2D Initialization */
    if(HAL_DMA2D_Init(&hdma2d_eval) == HAL_OK){
        if(HAL_DMA2D_ConfigLayer(&hdma2d_eval, 1) == HAL_OK){
            if(HAL_DMA2D_Start(&hdma2d_eval, (uint32_t)bitmap, 0, w, h) == HAL_OK){
                HAL_DMA2D_PollForTransfer(&hdma2d_eval, 10);
    return 1;   // Continue to decompress
UINT input_func(JDEC *jd, BYTE *buff, UINT ndata){
    IODEV *dev = (IODEV *)jd->device;
    ndata = dev->jsize - dev->joffset > ndata ? ndata : dev->jsize - dev->joffset;
    if(buff){
        memcpy(buff, dev->jpic + dev->joffset, ndata);
    dev->joffset += ndata;
    return ndata;
BSP_LCD_Clear(LCD_COLOR_WHITE);
rc = jd_prepare(&jd, input_func, jdwork, sizeof(jdwork), &iodev);
if(rc){
    BSP_LCD_Clear(LCD_COLOR_BLACK);
    while(1);
rc = jd_decomp(&jd, output_func, SCALE);
if(rc){
    while(1);
