8 bits DAC DMA config on STM32F2
Question asked by rocca.stephane on Oct 4, 2015
Latest reply on Oct 8, 2015 by Amel N
Hi all,
I am not sure about a DMA config for DAC on STM32F2. Could you please tell me if I made an error using 8bits words with this DMA config? Especially with DAC base address?
#define                 BUFFERSIZE                              128
__IO    uint8_t         DAC_data_8bits_DAC_1[ BUFFERSIZE ];
__IO    uint8_t         DAC_data_8bits_DAC_2[ BUFFERSIZE ];
    /// configure DMA  : DAC1           -> DAC_SetChannel1Data()
    DMA_InitTypeDef DMA_InitStructure;
    /* DMA1_Stream5 channel7 configuration **************************************/
    DMA_DeInit(DMA1_Stream5);
    DMA_InitStructure.DMA_Channel                   = DMA_Channel_7;
        DMA_InitStructure.DMA_PeripheralBaseAddr        = (uint32_t)( DAC_BASE + DHR12R1_OFFSET + DAC_Align_8b_R); ///
        DMA_InitStructure.DMA_Memory0BaseAddr           = (uint32_t)&DAC_data_8bits_DAC_1; //
        DMA_InitStructure.DMA_DIR                       = DMA_DIR_MemoryToPeripheral;
    DMA_InitStructure.DMA_BufferSize                = BUFFERSIZE;
    DMA_InitStructure.DMA_PeripheralInc             = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc                 = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize        = DMA_PeripheralDataSize_Byte; /// DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize            = DMA_MemoryDataSize_Byte; /// DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode                      = DMA_Mode_Normal; /// DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority                  = DMA_Priority_VeryHigh;
        DMA_InitStructure.DMA_FIFOMode                  = DMA_FIFOMode_Disable;
        DMA_InitStructure.DMA_FIFOThreshold             = DMA_FIFOThreshold_HalfFull;
        DMA_InitStructure.DMA_MemoryBurst               = DMA_MemoryBurst_Single;
        DMA_InitStructure.DMA_PeripheralBurst           = DMA_PeripheralBurst_Single;
    /// configure DMA  : DAC2           -> DAC_SetChannel2Data()
    /* DMA1_Stream6 channel7 configuration **************************************/
    DMA_DeInit(DMA1_Stream6);
        DMA_InitStructure.DMA_PeripheralBaseAddr        = (uint32_t)( DAC_BASE + DHR12R2_OFFSET + DAC_Align_8b_R); /// DAC_DHR8R2_DACC2DHR address
        DMA_InitStructure.DMA_Memory0BaseAddr           = (uint32_t)&DAC_data_8bits_DAC_2; //
    DMA_Init(DMA1_Stream5, &DMA_InitStructure);
    DMA_Init(DMA1_Stream6, &DMA_InitStructure);
    DMA_Cmd(DMA1_Stream5, ENABLE);
    DMA_Cmd(DMA1_Stream6, ENABLE);
    DAC_DMACmd(DAC_Channel_1, ENABLE);
    DAC_DMACmd(DAC_Channel_2, ENABLE);
    /* Enable DMA Stream Transfer Complete interrupt */
    DMA_ITConfig(   DMA1_Stream5_IRQn,  DMA_IT_TC, ENABLE); /// ---> DMA1_Stream5_IRQHandler()
    DMA_ITConfig(   DMA1_Stream6_IRQn,  DMA_IT_TC, ENABLE); /// ---> DMA1_Stream6_IRQHandler()
Thank you!
