Can a 'CSTACK' outside range Error be caused by a Hardware failure?
Question asked by hirshberg.yanir.001 on Aug 24, 2015
Latest reply on Aug 24, 2015 by Clive One
I've got a design that uses an F0, running at 3.3 Volts. When the board is 'fresh' (ie never powered up before) the part can be programmed and executes code normally. After about a day of development the developer reports that he gets stack buffer overrun errors. Code still executes however when the RTOS in use starts doing some more complex tasks this error occurs. The same code runs reliably on a different board using the same micro.
It seems like the part is damaged over time. The part appears to be healthy except for this error. Does anyone have an idea on what might cause this type of damage?
