stm32f338 ADC problem
Question asked by ASSAAD on Jul 31, 2015
Hello
I have problem with ADC of stm32f3 ;
it seems if I read multiple times  ; some reading return zero or the old reading ;
I read the ADC every 200uSec ;
for example
delay(200usec)
read_adcwill return wrong result or zero
 but it
delay(200usec)
read_adc
read_adc
it  gives right reading
what I am misising please could you guide ?
here is the code :
void ADC_Config(void)
 unsigned int i;
  ADC_InitTypeDef       ADC_InitStructure;
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
  /* ADC Channel configuration */
  /* Configure the ADC clock */
  RCC_ADCCLKConfig(RCC_ADC12PLLCLK_Div2);
  /* Enable ADC1 clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_ADC12, ENABLE);
  /* GPIOC Periph clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  /* Configure ADC1 Channel2 as analog input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 ;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  ADC_StructInit(&ADC_InitStructure);
  /* Calibration procedure */
  ADC_VoltageRegulatorCmd(ADC1, ENABLE);
  /* Insert delay equal to 10 µs */
//  Delay(10);
  for(i=0;i<0x00ffff;i++);
  ADC_SelectCalibrationMode(ADC1, ADC_CalibrationMode_Single);
  ADC_StartCalibration(ADC1);
  while(ADC_GetCalibrationStatus(ADC1) != RESET );
  calibration_value = ADC_GetCalibrationValue(ADC1);
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_CommonInitStructure.ADC_Clock = ADC_Clock_AsynClkMode;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  ADC_CommonInitStructure.ADC_DMAMode = ADC_DMAMode_OneShot;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = 0;
  ADC_CommonInit(ADC1, &ADC_CommonInitStructure);
  ADC_InitStructure.ADC_ContinuousConvMode = ADC_ContinuousConvMode_Disable;//ADC_ContinuousConvMode_Enable;
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ExternalTrigConvEvent = ADC_ExternalTrigConvEvent_0;
  ADC_InitStructure.ADC_ExternalTrigEventEdge = ADC_ExternalTrigEventEdge_None;
  ADC_InitStructure.ADC_OverrunMode = ADC_OverrunMode_Disable;
  ADC_InitStructure.ADC_AutoInjMode = ADC_AutoInjec_Disable;
  ADC_InitStructure.ADC_NbrOfRegChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel2 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_7Cycles5);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* wait for ADRDY */
  while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_RDY));
void ADC_Config_2(void)
 unsigned int i;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 ;
  ADC_VoltageRegulatorCmd(ADC2, ENABLE);
//  Delay(10);
  ADC_SelectCalibrationMode(ADC2, ADC_CalibrationMode_Single);
  ADC_StartCalibration(ADC2);
  while(ADC_GetCalibrationStatus(ADC2) != RESET );
  calibration_value_2 = ADC_GetCalibrationValue(ADC2);
  ADC_InitStructure.ADC_ContinuousConvMode =  ADC_ContinuousConvMode_Disable    ;//ADC_ContinuousConvMode_Enable;
  ADC_Init(ADC2, &ADC_InitStructure);
  /* ADC2 regular channel2 configuration */
ADC_RegularChannelConfig(ADC2, ADC_Channel_2, 1, ADC_SampleTime_7Cycles5);
  /* Enable ADC1 */
  ADC_Cmd(ADC2, ENABLE);
  while(!ADC_GetFlagStatus(ADC2, ADC_FLAG_RDY));
int main(void)
  uint8_t toggle = 0;
  double midvalue = 625;
  uint32_t i;
  float y;
  /* SysTick end of count event each 1ms */
  RCC_GetClocksFreq(&RCC_Clocks);
  SysTick_Config(RCC_Clocks.HCLK_Frequency / 1000);
     // SysTick_Config(SystemCoreClock / 1000000);
  /* Allows temporization */
    init_ports();
    ADC_Config();
                  ADC_Config_2();
while(1)
  while (1)
delay(); // 200uSEC
    /* Test EOC flag */
ADC_StartConversion(ADC1);
    while(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC) == RESET)
    /* Get ADC1 converted data */
    ADC1ConvertedValue = ADC_GetConversionValue(ADC1);
    /* Compute the voltage */
    ADC1ConvertedVoltage = (ADC1ConvertedValue *3300)/0xFFF;
  ADC_StartConversion(ADC2);
 while(ADC_GetFlagStatus(ADC2, ADC_FLAG_EOC) == RESET)
            /* Get ADC2 converted data */
    ADC2ConvertedValue = ADC_GetConversionValue(ADC2);
    ADC2ConvertedVoltage = (ADC2ConvertedValue *3300)/0xFFF;
Thank you in advanced
