STemWin on the STM32F46G Discovery board error
Question asked by mostowski.daniel on Jul 24, 2015
Hello Everyone,
I am using new board from STM32 and I added simple page from GUIBuilder from software included to library. When I run my code I click for example on slider widget I have some error. Slider changed his value, but when I click in other part of screen (not fitted in widget) his value still will be changed. Whole screen have focus on this widget only. I use settings to LCD from CubeF7 delivered by STM32 for this dev kit. Also I included part of code responsible for my window which not working. Maybe someone have this same problem, or maybe I use wrong file. I need some adwise where I need go to my project and where probably will search for reason.
static void _cbDialog(WM_MESSAGE * pMsg) {
  WM_HWIN hItem;
  int     NCode;
  int     Id;
  // USER START (Optionally insert additional variables)
  // USER END
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    // Initialization of 'Text'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
    TEXT_SetTextAlign(hItem, GUI_TA_LEFT | GUI_TA_VCENTER);
    TEXT_SetFont(hItem, GUI_FONT_32B_1);
    // USER START (Optionally insert additional code for further widget initialization)
    // USER END
    break;
  case WM_NOTIFY_PARENT:
    Id    = WM_GetId(pMsg->hWinSrc);
    NCode = pMsg->Data.v;
    switch(Id) {
    case ID_SLIDER_0: // Notifications sent by 'Slider'
      switch(NCode) {
      case WM_NOTIFICATION_CLICKED:
        // USER START (Optionally insert code for reacting on notification message)
        // USER END
        break;
      case WM_NOTIFICATION_RELEASED:
        // USER END
        break;
      case WM_NOTIFICATION_VALUE_CHANGED:
        // USER END
        break;
      // USER START (Optionally insert additional code for further notification handling)
      // USER END
      break;
    case ID_BUTTON_0: // Notifications sent by 'Button'
      switch(NCode) {
        // USER END
        break;
        // USER END
        break;
      // USER END
      break;
    case ID_BUTTON_1: // Notifications sent by 'Button'
      switch(NCode) {
        // USER END
        break;
        // USER END
        break;
      // USER END
      break;
    // USER START (Optionally insert additional code for further Ids)
    // USER END
    break;
  // USER START (Optionally insert additional message handling)
  // USER END
  default:
    WM_DefaultProc(pMsg);
    break;
And I call my window in this way.
WM_HWIN hWin;hWin = CreateSpinBoxTest();
GUI_Exec();
thank you in advance,
Daniel
