Power usage issue with STM32L1 in Stop & Standby modes
Question asked by simal.david on Jul 22, 2015
I'm unable to get close to the advertised power consumption with STM32L152CBT6 and STM32L151C8T6 MCUs (Both are revison V)
The test board is the simpliest possible: MCU, decoupling caps of 0.1µF on each VSS/VDD + one 10µF on top, 0.1µF on VREF and another on NRST. BOOT0 connected to ground, all caps are high quality multi layer ceramic SMD. Circuit is powered by a 3.0V regulated source and tests are made with ambiant temperature of 25°C
Please find the code used below. I get exactly the same consumption in Stop or Standby mode : 14.4µA, and if I disable the LSI it goes down to 13.7µA with the STM32L152CBT6 (2 different boards same result), with the STM32L151C8T6 (1 board) it is 15.7µA or 15.0 µA with LSI disabled (this test board has 8Mhz & 32.768Khz crystals connected with proper caps, but HSE/LSE are not used)
I have spent days searching online, forums and example code and we just can't get it any lower than this. This is pretty critical as I need to get < 2 µA consumption in stop mode with RTC (which shouldn't be a problem according to the datasheet), or it's a show stopper for this MCU
Please find the test code below:
 * File Name     : main.c
 * Date        : 07/05/2015 03:52:50
 * Description    : Main program body
 * COPYRIGHT(c) 2015 STMicroelectronics
 * Redistribution and use in source and binary forms, with or without modification,
 * are permitted provided that the following conditions are met:
 *  1. Redistributions of source code must retain the above copyright notice,
 *   this list of conditions and the following disclaimer.
 *  2. Redistributions in binary form must reproduce the above copyright notice,
 *   this list of conditions and the following disclaimer in the documentation
 *   and/or other materials provided with the distribution.
 *  3. Neither the name of STMicroelectronics nor the names of its contributors
 *   may be used to endorse or promote products derived from this software
 *   without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
 * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
 * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32l1xx_hal.h"
/* USER CODE END Includes */
RTC_HandleTypeDef hrtc;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_RTC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
 /* USER CODE BEGIN 1 */
 /* USER CODE END 1 */
 HAL_Init();
 SystemClock_Config();
 //MX_RTC_Init();
__GPIOA_CLK_ENABLE();
__GPIOB_CLK_ENABLE();
__GPIOC_CLK_ENABLE();
__GPIOD_CLK_ENABLE();
__GPIOE_CLK_ENABLE();
__GPIOH_CLK_ENABLE();
 GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
 GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;
 GPIO_InitStructure.Pull = GPIO_NOPULL;
 GPIO_InitStructure.Pin = GPIO_PIN_All;
 HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
 HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
 HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
 HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
 HAL_GPIO_Init(GPIOE, &GPIO_InitStructure);
 HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
__GPIOA_CLK_DISABLE();
__GPIOB_CLK_DISABLE();
__GPIOC_CLK_DISABLE();
__GPIOD_CLK_DISABLE();
__GPIOE_CLK_DISABLE();
__GPIOH_CLK_DISABLE();
//HAL_RCC_DeInit();
HAL_PWREx_DisableFastWakeUp();
HAL_PWR_DisablePVD();
HAL_PWREx_EnableUltraLowPower();
RCC->AHBENR = 0;
 RCC->AHBLPENR = 0; // Disables all peripheral clocks during sleep
 RCC->APB1ENR = 0; //RCC_APB1ENR_PWREN;
 RCC->APB2ENR = 0; // Disables all periph clocks including adc, spi, usart, ...
 RCC->APB1LPENR = 0; //RCC_APB1ENR_PWREN;
 RCC->APB2LPENR = 0; // Disables all periph clocks including adc, spi, usart, ...
SysTick->CTRL=0;
// Disable flash prefetch buffer, enable flash powerdown, seems to have no effect on power consumption
FLASH->ACR &=(~FLASH_ACR_PRFTEN);
SET_BIT(FLASH->ACR, FLASH_ACR_SLEEP_PD);
FLASH->PDKEYR = FLASH_PDKEY1;
 FLASH->PDKEYR = FLASH_PDKEY2;
 SET_BIT(FLASH->ACR, FLASH_ACR_RUN_PD);
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON,PWR_STOPENTRY_WFI);
// Exactly same power usage if I enter in STANDBY Mode instead
//HAL_PWR_EnterSTANDBYMode();
 while (1)
 /* USER CODE END WHILE */
 /* USER CODE BEGIN 3 */
 /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
  __PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_MSI;
  RCC_OscInitStruct.LSIState = RCC_LSI_ON;
  RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  RCC_OscInitStruct.MSICalibrationValue = 0;
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_5 ; // ~2Mhz
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0);
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC;
  PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
  __SYSCFG_CLK_ENABLE();
/* RTC init function */
  RTC_TimeTypeDef sTime;
  RTC_DateTypeDef sDate;
    /**Initialize RTC and set the Time and Date
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  HAL_RTC_Init(&hrtc);
  sTime.Hours = 0;
  sTime.Minutes = 0;
  sTime.Seconds = 0;
  sTime.TimeFormat = RTC_HOURFORMAT12_AM;
  sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sTime.StoreOperation = RTC_STOREOPERATION_RESET;
  HAL_RTC_SetTime(&hrtc, &sTime, FORMAT_BCD);
  sDate.WeekDay = RTC_WEEKDAY_MONDAY;
  sDate.Month = RTC_MONTH_JANUARY;
  sDate.Date = 1;
  sDate.Year = 0;
  HAL_RTC_SetDate(&hrtc, &sDate, FORMAT_BCD);
    /**Enable the WakeUp
  //HAL_RTCEx_SetWakeUpTimer(&hrtc, 0x1FFF, RTC_WAKEUPCLOCK_RTCCLK_DIV16);
 HAL_RTCEx_DeactivateWakeUpTimer(&hrtc);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
