SDRAM-based heap initialized as part of ZI-data
Question asked by Nicklesworth on Jun 11, 2015
I'm developing an application which requires the heap to be located in a large off-chip SDRAM. I'm using Keil uVision5 and scatter-loading to accomplish this. Functionally, all is good and works as expected.
One quirk I've noticed though is that the heap is linked into ZI-data, which is initialized to 0 in the C runtime. This creates a significant startup delay as the entire 32MB SDRAM is zero'ed. Is there a way to prevent the initialization from taking place? The scatter file I'm using is below...
Results after linking...notice the 32MB ZI-data!
Program Size: Code=26176 RO-data=956 RW-data=1512 ZI-data=33561488
Scatter File
#! armcc -E
; SCATTER FILE
; Note: By running armcc above, this file is sent to the C preprocessor
; This allows us to use a file like memory_map.h, which the code uses
; This should prevent mismatches in the code vs. scatter file
; Note: These #includes are done in a very specific order
#include "sdram.h"
#include "memory_map.h"
MAIN_APPLICATION MAIN_CODE_BASE_ADDRESS MAIN_CODE_SIZE
    ER_RESET_AND_LIBS +0
        *.o (RESET, +First) ; Locate vector table first
        *(InRoot$$Sections) ; All library sections that must be in a root region
        .ANY (+RO)          ; Any read-only data otherwise unspecified
    SRAM INTERNAL_SRAM_BASE_ADDRESS SRAM_SIZE
        .ANY (+RW +ZI)
    SDRAM_HEAP HEAP_LOCATION UNINIT HEAP_SIZE
        *(HEAP)
Relevant Startup Code (for completeness)
; C Inclusions (requires --cpreproc in assembler command!)
#include "sdram.h"
; Stack Definition
Stack_Size      EQU     STACK_SIZE
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; Heap Definition
Heap_Size       EQU     HEAP_SIZE
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
