[CubeMX] USB CDC library
Question asked by PatLas on Jun 3, 2015
Latest reply on Feb 4, 2017 by Available for a sales job
I've recently try to use code generated by CubeMX to prepare simple USB<->UART converter. Everything goes almost ok but inside function CDC_Control_FS(...) [usbd_cdc_if.c] in case "CDC_SET_LINE_CODING" inside buffer I should have received setting for uart (set on PC by user) but the only one setting that is inside function buffer is baud rate, nothing more :( Could somebody tell my why, or what shall I do to deal with that?
P.S Is there any maual for Cube library (I've found only sheet with about 58 pages)?
