SPGRF crytal tolerance
Question asked by szabo.laszlo on Apr 4, 2016
Dear Madam, Sir,
Would You inform me about the type of crystal what SPSGRF board uses.
I have developed and manufactured 250pcs Spirit1 boards with this crystals.
http://www.ndk.com/images/products/catalog/c_NX3225GA-STD-CRG-1_e.pdf
All my boards with my radio able to communicate to each other using FC_OFFSET1 = 0 and FC_OFFSET0 = 0 value. But those boards which area mounted the buyed SPGRS can't communicate with my radios. I know a can tune syntesizer of SPSGRF boards to my requirement.
Can You garantee that the your SPSGRF boards will mounted the same crystal in the future?
Need I check all buyed SPGRS modul crystal tolerance during manufacturing process all the time in all modul?
Thank Your answare in advance
Laszlo
ps.
My radio params are
#define XTAL_OFFSET_PPM
#define CHANNEL_SPACE                    250000
#define MODULATION_SELECT          GFSK_BT05
#define DATARATE                              250000
#define FREQ_DEVIATION                      DATARATE/4
#define BANDWIDTH                             DATARATE *12/10
