STM32F2 linker script to emulate EEPROM
Question asked by rocca.stephane on May 10, 2015
Latest reply on May 11, 2015 by rocca.stephane
Hi all,
I try to test the ST example of EEPROM emulation (with 3 variables and page2 + Page3 usage).
I build it with success with GCC (EMBLOCKS), but it seems I can't assign the good value to isr vector. I tried a lot of solution with custom linker script, but no way : I can't reset the MCU after upload.
Any help appreciated please !!
/*                  Em::Blocks embedded development Support                     */
/* Copyright (c) 2014, EmBlocks                                                 */
/* All rights reserved.                                                         */
/* Redistribution and use in source and binary forms, with or without           */
/* modification, are permitted provided that the following condition is met:    */
/* - Redistributions of source code must retain the above copyright notice,     */
/* this list of conditions and the disclaimer below.                            */
/* EmBlocks's name may not be used to endorse or promote products derived from  */
/* this software without specific prior written permission.                     */
/* DISCLAIMER:  THIS SOFTWARE IS PROVIDED BY EBLOCKS "AS IS" AND ANY EXPRESS OR */
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE   */
/* DISCLAIMED. IN NO EVENT SHALL EMBLOCKS BE LIABLE FOR ANY DIRECT, INDIRECT,   */
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,  */
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF    */
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING         */
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                           */
 *      Linker script for running in internal FLASH on the STM32F215RE
OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm")
OUTPUT_ARCH(arm)
SEARCH_DIR(.)
ROM  (rx) : ORIGIN = 0x08000000, LENGTH = 512K
ROM  (rx) : ORIGIN = 0x08010000, LENGTH = 448K
ROM  (rx) : ORIGIN = 0x08010000, LENGTH = 512K - 0x10000
ROM  (rx) : ORIGIN = 0x08020000, LENGTH = 320K : marche pas
/* Memory Spaces Definitions */
MEMORY
    RAM (rwx) : ORIGIN = 0x20000000, LENGTH = 128K
/* Linker script to place sections and symbol values. Should be used together
 * with other linker script that defines memory regions FLASH and RAM.
 * It references following symbols, which must be defined in code:
 *   Reset_Handler : Entry of reset handler
 * It defines following symbols, which code can use without definition:
 *   __exidx_start
 *   __exidx_end
 *   __etext
 *   __data_start__
 *   __preinit_array_start
 *   __preinit_array_end
 *   __init_array_start
 *   __init_array_end
 *   __fini_array_start
 *   __fini_array_end
 *   __data_end__
 *   __bss_start__
 *   __bss_end__
 *   __end__
 *   end
 *   __HeapLimit
 *   __StackLimit
 *   __StackTop
 *   __stack
SECTIONS
    .text :
        KEEP(*(.isr_vector))
        *(.text*)
        KEEP(*(.init))
        KEEP(*(.fini))
        /* .ctors */
        *crtbegin.o(.ctors)
        *crtbegin?.o(.ctors)
        *(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
        *(SORT(.ctors.*))
        *(.ctors)
        /* .dtors */
        *crtbegin.o(.dtors)
        *crtbegin?.o(.dtors)
        *(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
        *(SORT(.dtors.*))
        *(.dtors)
        *(.rodata*)
        KEEP(*(.eh_frame*))
    } > ROM
    .ARM.extab :
        *(.ARM.extab* .gnu.linkonce.armextab.*)
    } > ROM
    __exidx_start = .;
    .ARM.exidx :
        *(.ARM.exidx* .gnu.linkonce.armexidx.*)
    } > ROM
    __exidx_end = .;
    __etext = .;
    .data : AT (__etext)
        __data_start__ = .;
        *(vtable)
        *(.data*)
        . = ALIGN(4);
        /* preinit data */
        PROVIDE_HIDDEN (__preinit_array_start = .);
        KEEP(*(.preinit_array))
        PROVIDE_HIDDEN (__preinit_array_end = .);
        . = ALIGN(4);
        /* init data */
        PROVIDE_HIDDEN (__init_array_start = .);
        KEEP(*(SORT(.init_array.*)))
        KEEP(*(.init_array))
        PROVIDE_HIDDEN (__init_array_end = .);
        . = ALIGN(4);
        /* finit data */
        PROVIDE_HIDDEN (__fini_array_start = .);
        KEEP(*(SORT(.fini_array.*)))
        KEEP(*(.fini_array))
        PROVIDE_HIDDEN (__fini_array_end = .);
        . = ALIGN(4);
        /* All data end */
        __data_end__ = .;
    } > RAM
    .bss (NOLOAD):
        __bss_start__ = .;
        *(.bss*)
        *(COMMON)
        __bss_end__ = .;
    } > RAM
    .heap (NOLOAD):
        __end__ = .;
        end = __end__;
        *(.heap*)
        __HeapLimit = .;
    } > RAM
    /* .stack_dummy section doesn't contains any symbols. It is only
     * used for linker to calculate size of stack sections, and assign
     * values to stack symbols later */
    .stack_dummy (NOLOAD):
        *(.stack)
    } > RAM
    /* Set stack top to end of RAM, and stack limit move down by
     * size of stack_dummy section */
    __StackTop = ORIGIN(RAM) + LENGTH(RAM);
    __StackLimit = __StackTop - SIZEOF(.stack_dummy);
    PROVIDE(__stack = __StackTop);
    /* Check if data + heap + stack exceeds RAM limit */
    ASSERT(__StackLimit >= __HeapLimit, "region RAM overflowed with stack")
Other modifications :
#define VECT_TAB_OFFSET  0x10000
Tx !
