How to init GPIO on CubeMX generated code ?
Question asked by H.Rick on Apr 26, 2015
Latest reply on Apr 29, 2015 by Amel N
Guys,
I have generated a code for Keil from CubeMx but I can't initialize GPIO,
I can see a code in main.c below....anyone knows how to initialize GPIO,reset and set a bit on it at CubeMx generated code ??
I used LwIP,USB and RTOS and FatFS...
HAL_GPIO_Init(GPIOE, GPIO_CR_CNF_GP_OUTPUT_PP );
  /* USER CODE BEGIN 5 */
  /* Infinite loop */
  for(;;)
          HAL_GPIO_WritePin(GPIOE,5,0);
      osDelay(2000000);
      HAL_GPIO_WritePin(GPIOE,5,1);
          osDelay(2000000);
    osDelay(1);
  /* USER CODE END 5 */
complete main.c :
  * File Name          : main.c
  * Date               : 26/04/2015 05:25:33
  * Description        : Main program body
  * COPYRIGHT(c) 2015 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f1xx_hal.h"
#include "cmsis_os.h"
#include "fatfs.h"
#include "lwip.h"
#include "usb_host.h"
//Define LED port begin
/* led connected to a gpio pin */
#define LED1_PIN    GPIO_Pin_0
#define LED1_PORT   GPIOB
#define LED2_PIN    GPIO_Pin_3
#define LED2_PORT   GPIOC
//#define LED3_PIN    GPIO_Pin_0
//#define LED3_PORT   GPIOA
//#define LED4_PIN    GPIO_Pin_0
//#define LED4_PORT   GPIOE
#define LED3_PIN    GPIO_Pin_5
#define LED3_PORT   GPIOE
#define LED4_PIN    GPIO_Pin_6
#define LED1_D_PIN    GPIO_Pin_5
#define LED1_D_PORT   GPIOD
//Define LED port END
/* USER CODE END Includes */
USART_HandleTypeDef husart2;
osThreadId defaultTaskHandle;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_USART2_Init(void);
void StartDefaultTask(void const * argument);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_USART2_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* USER CODE BEGIN RTOS_MUTEX */
  /* add mutexes, ... */
  /* USER CODE END RTOS_MUTEX */
  /* USER CODE BEGIN RTOS_SEMAPHORES */
  /* add semaphores, ... */
  /* USER CODE END RTOS_SEMAPHORES */
  /* USER CODE BEGIN RTOS_TIMERS */
  /* start timers, add new ones, ... */
  /* USER CODE END RTOS_TIMERS */
  /* Create the thread(s) */
  /* definition and creation of defaultTask */
  osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 128);
  defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);
  /* USER CODE BEGIN RTOS_THREADS */
  /* add threads, ... */
  /* USER CODE END RTOS_THREADS */
  /* USER CODE BEGIN RTOS_QUEUES */
  /* add queues, ... */
  /* USER CODE END RTOS_QUEUES */
  /* Start scheduler */
  osKernelStart();
  /* We should never get here as control is now taken by the scheduler */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.Prediv1Source = RCC_PREDIV1_SOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6;
  RCC_OscInitStruct.PLL2.PLL2State = RCC_PLL_NONE;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USB;
  PeriphClkInit.UsbClockSelection = RCC_USBPLLCLK_DIV2;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
  __HAL_RCC_AFIO_CLK_ENABLE();
/* USART2 init function */
  husart2.Instance = USART2;
  husart2.Init.BaudRate = 115200;
  husart2.Init.WordLength = USART_WORDLENGTH_8B;
  husart2.Init.StopBits = USART_STOPBITS_1;
  husart2.Init.Parity = USART_PARITY_NONE;
  husart2.Init.Mode = USART_MODE_TX_RX;
  husart2.Init.CLKPolarity = USART_POLARITY_LOW;
  husart2.Init.CLKPhase = USART_PHASE_1EDGE;
  husart2.Init.CLKLastBit = USART_LASTBIT_DISABLE;
  HAL_USART_Init(&husart2);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
    __HAL_RCC_GPIOE_CLK_ENABLE();
    //PORT E ALL PINS OUT
    /*Configure GPIO pins : PC13 PC14 PC15 PC0
                           PC1 PC2 PC3 PC4
                           PC5 PC6 PC7 PC8
                           PC9 PC10 PC11 PC12 */
  GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15|GPIO_PIN_0
                          |GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4
                          |GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8
                          |GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12;
  //GPIO_InitStruct.Pull = GPIO_PULLUP;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pins : PD8 PD9 PD10 PD11
                           PD12 PD13 PD14 PD15
                           PD0 PD1 PD2 PD3
                           PD4 PD5 PD6 PD7 */
  GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
/* StartDefaultTask function */
  /* init code for FATFS */
  MX_FATFS_Init();
  /* init code for LWIP */
  MX_LWIP_Init();
  /* init code for USB_HOST */
  MX_USB_HOST_Init();
  /* init code for GPIO */
    // MX_GPIO_Init();
  /* Infinite loop */
  for(;;)
          HAL_GPIO_WritePin(GPIOE,GPIO_PIN_5,GPIO_PIN_RESET);
      osDelay(200);
      HAL_GPIO_WritePin(GPIOE,GPIO_PIN_5,GPIO_PIN_SET);
          osDelay(200);
        osDelay(1);
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
thanks
