eeprom emulation stm32
Question asked by mahir on Apr 10, 2015
Latest reply on Apr 14, 2015 by mahir
hi all
How do I write
and I read a 32-bit number?
for example
unsigned long counter
= 4000000000:
thanks
/******************** (C) COPYRIGHT 2007 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V1.0
* Date               : 10/08/2007
* Description        : Main program body
* THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
#include "eeprom.h"
ErrorStatus HSEStartUpStatus;
u16 VarValue = 0;
FLASH_Status FlashStatus;
/* Virtual address defined by the user: 0xFFFF value is prohibited */
u16 VirtAddVarTab[NumbOfVar] = {0x5555, 0x6666, 0x7777};
void RCC_Configuration(void);
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* Unlock the Flash Program Erase controller */
  FLASH_Unlock();
  /* EEPROM Format */
  FlashStatus = EE_Format();
  /* --- Store successively many values of the three variables in the EEPROM --- */
  /* Store 1000 values of Variable1 in EEPROM */
  for (VarValue = 0; VarValue < 1000; VarValue++)
    EE_WriteVariable(VirtAddVarTab[0], VarValue);
  /* Store 500 values of Variable2 in EEPROM */
  for (VarValue = 0; VarValue < 500; VarValue++)
    EE_WriteVariable(VirtAddVarTab[1], VarValue);
  /* Store 800 values of Variable3 in EEPROM */
  for (VarValue = 0; VarValue < 800; VarValue++)
    EE_WriteVariable(VirtAddVarTab[2], VarValue);
  while(1);
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
* File Name          : eeprom.c
* Version            : V1.0
* Date               : 10/08/2007
* Description        : This file provides all the EEPROM emulation firmware functions.
#include "eeprom.h"
/* Global variable used to store variable value in read sequence */
u16 DataVar = 0 ;
extern u16 VirtAddVarTab[NumbOfVar];
static u16 EE_FindValidPage(u8 operation);
static u16 EE_VerifyPageFullWriteVariable(u16 VirtAddress, u16 Data);
static u16 EE_PageTransfer(u16 VirtAddress, u16 Data);
* Function Name  : EE_Format
* Description    : Erases PAGE0 and PAGE1 and writes VALID_PAGE header to PAGE0
* Input          : None
* Output         : None
* Return         : Status of the last operation (Flash write or erase) done during
*                  EEPROM formating
FLASH_Status EE_Format(void)
  FLASH_Status FlashStatus = FLASH_COMPLETE;
  /* Erase Page0 */
  FlashStatus = FLASH_ErasePage(PAGE0_BASE_ADDRESS);
  /* If erase operation was failed, a Flash error code is returned */
  if (FlashStatus != FLASH_COMPLETE)
    return FlashStatus;
  /* Set Page0 as valid page: Write VALID_PAGE at Page0 base address */
  FlashStatus = FLASH_ProgramHalfWord(PAGE0_BASE_ADDRESS, VALID_PAGE);
  /* If program operation was failed, a Flash error code is returned */
    return FlashStatus;
  /* Erase Page1 */
  FlashStatus = FLASH_ErasePage(PAGE1_BASE_ADDRESS);
  /* Return Page1 erase operation status */
  return FlashStatus;
* Function Name  : EE_FindValidPage
* Description    : Find valid Page for write or read operation
* Input          : - Operation: operation to achieve on the valid page:
*                      - READ_FROM_VALID_PAGE: read operation from valid page
*                      - WRITE_IN_VALID_PAGE: write operation from valid page
* Output         : None
* Return         : Valid page number (PAGE0 or PAGE1) or NO_VALID_PAGE in case
*                  of no valid page was found
u16 EE_FindValidPage(u8 Operation)
  u16 PageStatus0 = 6, PageStatus1 = 6;
  /* Get Page0 actual status */
#ifdef MOD_MTHOMAS_STMLIB
  /* workaround a warning - search better solution */
  vu32 t = PAGE0_BASE_ADDRESS;
  PageStatus0 = (*(vu16*)t);
#else
  PageStatus0 = (*(vu16*)PAGE0_BASE_ADDRESS);
#endif
  /* Get Page1 actual status */
  PageStatus1 = (*(vu16*)PAGE1_BASE_ADDRESS);
  /* Write or read operation */
  switch (Operation)
    case WRITE_IN_VALID_PAGE:   /* ---- Write operation ---- */
      if (PageStatus1 == VALID_PAGE)
        /* Page0 receiving data */
        if (PageStatus0 == RECEIVE_DATA)
          return PAGE0;   /* Page0 valid */
        else
          return PAGE1;   /* Page1 valid */
      else if (PageStatus0 == VALID_PAGE)
        /* Page1 receiving data */
        if (PageStatus1 == RECEIVE_DATA)
        else
      else
        return NO_VALID_PAGE;   /* No valid Page */
    case READ_FROM_VALID_PAGE:  /* ---- Read operation ---- */
      else if (PageStatus1 == VALID_PAGE)
      else
        return NO_VALID_PAGE ;  /* No valid Page */
    default:
* Function Name  : EE_VerifyPageFullWriteVariable
* Description    : Verify if active page is full and Writes variable in EEPROM.
* Input          : - VirtAddress: 16 bit virtual address of the variable
*                  - Data: 16 bit data to be written as variable value
* Output         : None
* Return         : - Success or error status:
*                      - FLASH_COMPLETE: on success
*                      - PAGE_FULL: if valid page is full
*                      - NO_VALID_PAGE: if no valid page was found
*                      - Flash error code: on write Flash error
  u16 ValidPage = PAGE0;
  u32 Address = 0x08010000, PageEndAddress = 0x080107FF;
  /* Get valid Page for write operation */
  ValidPage = EE_FindValidPage(WRITE_IN_VALID_PAGE);
  /* Check if there is no valid page */
  if (ValidPage == NO_VALID_PAGE)
  /* Get the valid Page start Address */
  Address = (u32)(EEPROM_START_ADDRESS + (u32)(ValidPage * PAGE_SIZE));
  /* Get the valid Page end Address */
  PageEndAddress = (u32)((EEPROM_START_ADDRESS - 2) + (u32)((1 + ValidPage) * PAGE_SIZE));
  /* Check each active page address starting from beginning */
  while (Address < PageEndAddress)
    /* Verify each time if Address and Address+2 contents are equal to Data and VirtAddress respectively */
    if (((*(vu16*)Address) == Data) && ((*(vu16*)(Address + 2)) == VirtAddress))
      return FLASH_COMPLETE;
    /* Verify if Address and Address+2 contents are 0xFFFFFFFF */
    if ((*(vu32*)Address) == 0xFFFFFFFF)
      /* Set variable data */
      FlashStatus = FLASH_ProgramHalfWord(Address, Data);
        return FlashStatus;
      /* Set variable virtual address */
      FlashStatus = FLASH_ProgramHalfWord(Address + 2, VirtAddress);
      /* Return program operation status */
      return FlashStatus;
    else
      /* Next address location */
      Address = Address + 4;
  /* Return PAGE_FULL in case the valid page is full */
  return PAGE_FULL;
* Function Name  : EE_ReadVariable
* Description    : Returns the last stored variable data, if found, which
*                  correspond to the passed virtual address
* Input          : - VirtAddress: Variable virtual address
*                  - Read_data: Global variable contains the read variable value
* Output         : None
*                      - 0: if variable was found
*                      - 1: if the variable was not found
*                      - NO_VALID_PAGE: if no valid page was found.
u16 EE_ReadVariable(u16 VirtAddress, u16* ReadData)
  u16 AddressValue = 0x5555, ReadStatus = 1;
  u32 Address = 0x08010000, PageStartAddress = 0x08010000;
  /* Get active Page for read operation */
  ValidPage = EE_FindValidPage(READ_FROM_VALID_PAGE);
  PageStartAddress = (u32)(EEPROM_START_ADDRESS + (u32)(ValidPage * PAGE_SIZE));
  /* Check each active page address starting from end */
  while (Address > (PageStartAddress + 2))
    /* Get the current location content to be compared with virtual address */
    AddressValue = (*(vu16*)Address);
    /* Compare the read address with the virtual address */
    if (AddressValue == VirtAddress)
      /* Get content of Address-2 which is variable value */
      *ReadData = (*(vu16*)(Address - 2));
      /* In case variable value is read, reset ReadStatus flag */
      ReadStatus = 0;
      break;
    else
      Address = Address - 4;
  /* Return ReadStatus value: (0: variable exist, 1: variable doesn't exist) */
  return ReadStatus;
* Function Name  : EE_PageTransfer
* Description    : Transfers last updated variable data from the full Page to
*                  an empty one.
* Output         : None
*                      - FLASH_COMPLETE: on success,
  u32 NewPageAddress = 0x080103FF, OldPageAddress = 0x08010000;
  u16 ValidPage = PAGE0, VarIdx = 0;
  u16 EepromStatus = 0, ReadStatus = 0;
  if (ValidPage == PAGE1)        /* Page1 valid */
    /* New page address where variable will be moved to */
    NewPageAddress = PAGE0_BASE_ADDRESS;
    /* Old page address where variable will be taken from */
    OldPageAddress = PAGE1_BASE_ADDRESS;
  else if (ValidPage == PAGE0)   /* Page0 valid */
    NewPageAddress = PAGE1_BASE_ADDRESS;
    OldPageAddress = PAGE0_BASE_ADDRESS;
  else
  /* Set the new Page status to RECEIVE_DATA status */
  FlashStatus = FLASH_ProgramHalfWord(NewPageAddress, RECEIVE_DATA);
    return FlashStatus;
  /* Write the variable passed as parameter in the new active page */
  EepromStatus = EE_VerifyPageFullWriteVariable(VirtAddress, Data);
  if (EepromStatus != FLASH_COMPLETE)
    return EepromStatus;
  /* Transfer process: transfer variables from old to the new active page */
  for (VarIdx = 0; VarIdx < NumbOfVar; VarIdx++)
    if (VirtAddVarTab[VarIdx] != VirtAddress)  /* Check each variable except the one passed as parameter */
      /* Read the other last variable updates */
      ReadStatus = EE_ReadVariable(VirtAddVarTab[VarIdx], &DataVar);
      /* In case variable corresponding to the virtual address was found */
      if (ReadStatus != 0x1)
        /* Transfer the variable to the new active page */
        EepromStatus = EE_VerifyPageFullWriteVariable(VirtAddVarTab[VarIdx], DataVar);
  /* Erase the old Page: Set old Page status to ERASED status */
  FlashStatus = FLASH_ErasePage(OldPageAddress);
    return FlashStatus;
  /* Set new Page status to VALID_PAGE status */
  FlashStatus = FLASH_ProgramHalfWord(NewPageAddress, VALID_PAGE);
    return FlashStatus;
  /* Return last operation flash status */
  return FlashStatus;
* Function Name  : EE_WriteVariable
* Description    : Writes/updates variable data in EEPROM.
* Output         : None
u16 EE_WriteVariable(u16 VirtAddress, u16 Data)
  u16 Status = 0;
  /* Write the variable virtual address and value in the EEPROM */
  /* In case the EEPROM active page is full */
  if (Status == PAGE_FULL)
    /* Perform Page transfer */
    Status = EE_PageTransfer(VirtAddress, Data);
  /* Return last operation status */
  return Status;
* File Name          : eeprom.h
* Author             : MCD Application Team, minor modification by M. Thomas
* Version            : V1.0.1
* Date               : 10/08/2007 (modified 27. April 2009)
* Description        : This file contains all the functions prototypes for the
*                      EEPROM emulation firmware library.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __EEPROM_H
#define __EEPROM_H
#include "stm32f10x.h"
/* Exported constants --------------------------------------------------------*/
/* Page size */
#define PAGE_SIZE  (u16)0x400  /* 1KByte */
//* EEPROM start address in Flash */
extern u32 _seemul;
#define EEPROM_START_ADDRESS  ((u32)&_seemul) /* start of emulated EEPROM def'd in linker-script */
/// #define EEPROM_START_ADDRESS  (u32)(0x08000000+((128-2)*1024))
#else
#define EEPROM_START_ADDRESS  (u32)0x08010000 /* EEPROM emulation start address:
                                              after 64KByte of used Flash memory */
#endif /* MOD_MTHOMAS_STMLIB */
/* Pages 0 and 1 base and end addresses */
#define PAGE0_BASE_ADDRESS  (u32)(EEPROM_START_ADDRESS + (u16)0x0000)
#define PAGE0_END_ADDRESS   (u32)(EEPROM_START_ADDRESS + (PAGE_SIZE - 1))
#define PAGE1_BASE_ADDRESS  (u32)(EEPROM_START_ADDRESS + PAGE_SIZE)
#define PAGE1_END_ADDRESS   (u32)(EEPROM_START_ADDRESS + (2 * PAGE_SIZE - 1))
/* Used Flash pages for EEPROM emulation */
#define PAGE0    (u16)0x0000
#define PAGE1    (u16)0x0001
/* No valid page define */
#define NO_VALID_PAGE    (u16)0x00AB
/* Page status definitions */
#define ERASED             (u16)0xFFFF      /* PAGE is empty */
#define RECEIVE_DATA       (u16)0xEEEE      /* PAGE is marked to receive data */
#define VALID_PAGE         (u16)0x0000      /* PAGE containing valid data */
/* Valid pages in read and write defines */
#define READ_FROM_VALID_PAGE    (u8)0x00
#define WRITE_IN_VALID_PAGE     (u8)0x01
/* Page full define */
#define PAGE_FULL    (u8)0x80
/* Variables' number */
#define NumbOfVar  (u8)0x03
/* Exported types ------------------------------------------------------------*/
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
FLASH_Status EE_Format(void);
u16 EE_ReadVariable(u16 VirtAddress, u16* Read_data);
u16 EE_WriteVariable(u16 VirtAddress, u16 Data);
#endif /* __EEPROM_H */
