my ADC code cann't get value
Question asked by dai.enming on Mar 4, 2015
Latest reply on Mar 11, 2015 by Clive One
  MX_ADC2_Init();
  MX_ADC3_Init();
  MX_ADC1_Init();
    if(HAL_ADC_Start(&hadc1) != HAL_OK)
    Error_Handler();
      if(HAL_ADC_Start(&hadc2) != HAL_OK)
    /* Start Error */    Error_Handler();
    if(HAL_ADC_Start(&hadc3) != HAL_OK)
    Error_Handler();
  ADC_MultiModeTypeDef   mode;
  mode.Mode = ADC_TRIPLEMODE_INTERL;
  mode.DMAAccessMode = ADC_DMAACCESSMODE_3;
  mode.TwoSamplingDelay = ADC_TWOSAMPLINGDELAY_20CYCLES;
  if(HAL_ADCEx_MultiModeConfigChannel(&hadc1, &mode) != HAL_OK)
    /* Channel Configuration Error */
    Error_Handler();
  if(HAL_ADCEx_MultiModeConfigChannel(&hadc2, &mode) != HAL_OK)
    Error_Handler();
  if(HAL_ADCEx_MultiModeConfigChannel(&hadc3, &mode) != HAL_OK)
    Error_Handler();
    if(HAL_ADCEx_MultiModeStart_DMA(&hadc1, (uint32_t*)&uhADCxConvertedValue, 10240) != HAL_OK)
    /* Start Error */
    Error_Handler();
void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig_ADC1;
  __ADC1_CLK_ENABLE();
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4;
  hadc1.Init.Resolution = ADC_RESOLUTION8b;
  hadc1.Init.ScanConvMode = ENABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.NbrOfDiscConversion = 0;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_CC1;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 12;
  hadc1.Init.DMAContinuousRequests = ENABLE;
  hadc1.Init.EOCSelection = EOC_SINGLE_CONV;
  HAL_ADC_Init(&hadc1);
  sConfig_ADC1.Channel = ADC_CHANNEL_0;
  sConfig_ADC1.Rank = 1;
  sConfig_ADC1.SamplingTime = ADC_SAMPLETIME_480CYCLES;
  HAL_ADC_ConfigChannel(&hadc1, &sConfig_ADC1);
  sConfig_ADC1.Channel = ADC_CHANNEL_1;
  sConfig_ADC1.Rank = 2;
  sConfig_ADC1.Channel = ADC_CHANNEL_2;
  sConfig_ADC1.Rank = 3;
  sConfig_ADC1.Channel = ADC_CHANNEL_3;
  sConfig_ADC1.Rank = 4;
  sConfig_ADC1.Channel = ADC_CHANNEL_4;
  sConfig_ADC1.Rank = 5;
  sConfig_ADC1.Channel = ADC_CHANNEL_5;
  sConfig_ADC1.Rank = 6;
  sConfig_ADC1.Channel = ADC_CHANNEL_6;
  sConfig_ADC1.Rank = 7;
  sConfig_ADC1.Channel = ADC_CHANNEL_7;
  sConfig_ADC1.Rank = 8;
  sConfig_ADC1.Channel = ADC_CHANNEL_8;
  sConfig_ADC1.Rank = 9;
  sConfig_ADC1.Channel = ADC_CHANNEL_9;
  sConfig_ADC1.Rank = 10;
  sConfig_ADC1.Channel = ADC_CHANNEL_10;
  sConfig_ADC1.Rank = 11;
  sConfig_ADC1.Channel = ADC_CHANNEL_11;
  sConfig_ADC1.Rank = 12;
void MX_ADC2_Init(void)
  ADC_ChannelConfTypeDef sConfig_ADC2;
  __ADC2_CLK_ENABLE();
  hadc2.Instance = ADC2;
  hadc2.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4;
  hadc2.Init.Resolution = ADC_RESOLUTION8b;
  hadc2.Init.ScanConvMode = ENABLE;
  hadc2.Init.ContinuousConvMode = ENABLE;
  hadc2.Init.DiscontinuousConvMode = DISABLE;
  hadc2.Init.NbrOfDiscConversion = 0;
  hadc2.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc2.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_CC1;
  hadc2.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc2.Init.NbrOfConversion = 1;
  hadc2.Init.DMAContinuousRequests = ENABLE;
  hadc2.Init.EOCSelection = EOC_SINGLE_CONV;
  HAL_ADC_Init(&hadc2);
  sConfig_ADC2.Channel = ADC_CHANNEL_12;
  sConfig_ADC2.Rank = 1;
  HAL_ADC_ConfigChannel(&hadc2, &sConfig_ADC2);
/* ADC init function */
void MX_ADC3_Init(void)
  ADC_ChannelConfTypeDef sConfig_ADC3;
  __ADC3_CLK_ENABLE();
  hadc3.Instance = ADC3;
  hadc3.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4;
  hadc3.Init.Resolution = ADC_RESOLUTION8b;
  hadc3.Init.ScanConvMode = ENABLE;
  hadc3.Init.ContinuousConvMode = ENABLE;
  hadc3.Init.DiscontinuousConvMode = DISABLE;
  hadc3.Init.NbrOfDiscConversion = 1;
  hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc3.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_CC1;
  hadc3.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc3.Init.NbrOfConversion = 8;
  hadc3.Init.DMAContinuousRequests = ENABLE;
  hadc3.Init.EOCSelection = EOC_SINGLE_CONV;
  HAL_ADC_Init(&hadc3);
  sConfig_ADC3.Channel = ADC_CHANNEL_4;
  sConfig_ADC3.Rank = 1;
  sConfig_ADC3.SamplingTime = ADC_SAMPLETIME_480CYCLES;
  HAL_ADC_ConfigChannel(&hadc3, &sConfig_ADC3);
  sConfig_ADC3.Channel = ADC_CHANNEL_5;
  sConfig_ADC3.Rank = 2;
  sConfig_ADC3.Channel = ADC_CHANNEL_6;
  sConfig_ADC3.Rank = 3;
  sConfig_ADC3.Channel = ADC_CHANNEL_7;
  sConfig_ADC3.Rank = 4;
  sConfig_ADC3.Channel = ADC_CHANNEL_8;
  sConfig_ADC3.Rank = 5;
  sConfig_ADC3.Channel = ADC_CHANNEL_9;
  sConfig_ADC3.Rank = 6;
  sConfig_ADC3.Channel = ADC_CHANNEL_14;
  sConfig_ADC3.Rank = 7;
  sConfig_ADC3.Channel = ADC_CHANNEL_15;
  sConfig_ADC3.Rank = 8;
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
  if (hadc == &hadc3)
//    PF6 ------>ADC3_IN4   IR1
//    PF7 ------>ADC3_IN5      IR2
//    PF8 ------>ADC3_IN6   IR3
//    PF9 ------>ADC3_IN7   IR4
//    PF10------>ADC3_IN8   IR5
//    PF3 ------>ADC3_IN9   IR6
//    PF4 ------>ADC3_IN14   IR7
//    PF5 ------>ADC3_IN15   IR8
    GPIO_InitStruct.Pin = IR_DAT_PIN0|IR_DAT_PIN1|IR_DAT_PIN2|IR_DAT_PIN3
                          |IR_DAT_PIN4|IR_DAT_PIN5|IR_DAT_PIN6|IR_DAT_PIN7;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    HAL_GPIO_Init(IR_DAT_PORT, &GPIO_InitStruct);
  if (hadc == &hadc2)
    GPIO_InitStruct.Pin = GPIO_PIN_2;
  if (hadc == &hadc1)
    /**ADC1 GPIO Configuration
    PA0-WKUP     ------> ADC1_IN0
    PA1     ------> ADC1_IN1
    PA2     ------> ADC1_IN2
    PA3     ------> ADC1_IN3
    PA4     ------> ADC1_IN4
    PA5     ------> ADC1_IN5
    PA6     ------> ADC1_IN6
    PA7     ------> ADC1_IN7
    PB0     ------> ADC1_IN8
    PB1     ------> ADC1_IN9
    PC0     ------> ADC1_IN10
    PC1     ------> ADC1_IN11
    GPIO_InitStruct.Pin = M_DAT_PIN0|M_DAT_PIN1|M_DAT_PIN2|M_DAT_PIN3|M_DAT_PIN4|
    M_DAT_PIN5|M_DAT_PIN6|M_DAT_PIN7;
    GPIO_InitStruct.Pin = M_DAT_PIN8|M_DAT_PIN9;
    GPIO_InitStruct.Pin = M_DAT_PIN10|M_DAT_PIN11;
    //ADC1 IO CONFIG FINISH
    GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3;
    __DMA2_CLK_ENABLE();
    hdma_adc1.Instance = DMA2_Stream0;
    hdma_adc1.Init.Channel = DMA_CHANNEL_0;
    hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
    hdma_adc1.Init.PeriphDataAlignment = DMA_MDATAALIGN_WORD;
    hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
    hdma_adc1.Init.Mode = DMA_CIRCULAR;
    hdma_adc1.Init.Priority = DMA_PRIORITY_HIGH;
    hdma_adc1.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    hdma_adc1.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_HALFFULL;
    hdma_adc1.Init.MemBurst = DMA_MBURST_SINGLE;
    hdma_adc1.Init.PeriphBurst = DMA_PBURST_SINGLE;
    HAL_DMA_Init(&hdma_adc1);
    __HAL_LINKDMA(hadc,DMA_Handle,hdma_adc1);
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* AdcHandle)
   here is unable run.......
