Using emmc and fatfs with STM32F207
Question asked by ghislain.olivier on Mar 4, 2015
Latest reply on Mar 4, 2015 by Clive One
Dears,
I plan tu use an eMMC memory chip with an STMF32f207 connected to the SDIO interface (4-bits wide) and an FAT lib (from ST). The eMMC choice is dictated by wear levelling and ECC management facilities.
All the system will run under FreeRTOS.
I never do it before and before begining the hardware, I should answer to some questions:
1) Is it complexe to develop the low-level driver between the FAT lib and the eMMC.
2) In the past I have been developed a driver for NOR serial Flash and before programming byte in a non-erased sector, the driver should read all sector before changing data (classical scheme). Is it the same with eMMC and should the STM32 get enough RAM to read entire sector (some NOR flash have 256kb sector)
Thanks for your help
Olivier
