font problem
Question asked by mahir on Jan 20, 2015
Latest reply on Jan 20, 2015 by mahir
hi
I adapt my code to use the c51 stm32f103.
but I get the font errors.
How do I fix this error?
thanks
//**********************************main.c********************************************************
#include <stm32f10x.h>
#include <stm32f10x_conf.h>
#include <stm32f10x_rcc.h>
#include <stm32f10x_gpio.h>
#include "fonts.h"
#include <stdio.h>
#include <string.h>
#define  PORT     GPIOB
#define   _WR     GPIO_Pin_8
#define   RS      GPIO_Pin_9
#define   B0      0   //DATA PORT
#define  REST     GPIOC
#define  RES      GPIO_Pin_0//RST
#define  CS       GPIO_Pin_1//CS
void LCD_InitializePorts(void);
void Write_Cmd_Data (unsigned char x);
void Write_Cmd(unsigned char DL);
void Write_Data(unsigned char DH,unsigned char DL);
void LCD_Initial(void);
void delayms(unsigned int count);
void Print  (unsigned int x,unsigned int y,unsigned char *str,unsigned int dcolor,unsigned int bgcolor);
void GotoXY (unsigned int x,unsigned int y,unsigned char value,unsigned int dcolor,unsigned int bgcolor);
static void LCD_SetPos(unsigned char x0,unsigned char x1,unsigned int y0,unsigned int y1);
    int i,j;
    for(i=0;i<count;i++)
         for(j=0;j<125;j++);
     GPIO_SetBits(REST, GPIO_Pin_1);   //CS=1;
    delayms(5);
    GPIO_ResetBits(REST, GPIO_Pin_0);  //RES=0;
    delayms(10);
    GPIO_SetBits(REST, GPIO_Pin_0);   //RES=1;
    delayms(120);
  Write_Cmd(0xE9);
  Write_Cmd_Data(0x20);
  Write_Cmd(0x11);// Exit_sleep_mode
  delayms(100);
  Write_Cmd(0xD1);//Power_Setting
  Write_Cmd_Data(0x00);
  Write_Cmd_Data(0x71);//59  VCOH
  Write_Cmd_Data(0x19);//15 VCOM AP
  Write_Cmd(0xD0);//VCOM Control
  Write_Cmd_Data(0x07);//07
  Write_Cmd_Data(0x01);//01
  Write_Cmd_Data(0x08);//04
  Write_Cmd(0x36);//Set_address_mode 8
  Write_Cmd_Data(0x48);//normal
  Write_Cmd(0x3A);//Display_Timing_Setting for Normal/Partial Mode
  Write_Cmd_Data(0x05);
  Write_Cmd(0xC1);//Display_Timing_Setting for Normal/Partial Mode
  Write_Cmd_Data(0x10);
  Write_Cmd_Data(0x02);
  Write_Cmd(0xC0);//Panel Driving Setting
  Write_Cmd_Data(0x35);
  Write_Cmd(0xC5);//Frame Rate Control
  Write_Cmd_Data(0x04);
  Write_Cmd(0xD2);//Power_Setting for Normal Mode
  Write_Cmd_Data(0x44);
  Write_Cmd(0xC8);//SET GAMMA
  Write_Cmd_Data(0x67);
  Write_Cmd_Data(0x06);
  Write_Cmd_Data(0x24);
  Write_Cmd_Data(0x37);
  Write_Cmd_Data(0x40);
  Write_Cmd_Data(0x03);
  Write_Cmd_Data(0x80);
  Write_Cmd(0x2A); //Frame rate control
  Write_Cmd_Data(0xEF);
  Write_Cmd(0x2B); //Display function control
  Write_Cmd_Data(0x8F);
  Write_Cmd(0x29);//DISPLAY ON
  delayms(120);
  Write_Cmd(0x2C);//Write memory start
unsigned char YSH,YSL,YEH,YEL;
    YSH=y0>>8;
    YSL=y0;
    YEH=y1>>8;
    YEL=y1;
     Write_Cmd(0x2A);
    Write_Cmd_Data (0x00);
    Write_Cmd_Data (x0);
    Write_Cmd_Data (x1);
    Write_Cmd(0x2B);
    Write_Cmd_Data (YSH);
    Write_Cmd_Data (YSL);
    Write_Cmd_Data (YEH);
    Write_Cmd_Data (YEL);
    Write_Cmd(0x2C);//LCD_WriteCMD(GRAMWR);
unsigned char i,j;
unsigned char *str;
    str=font1;
    LCD_SetPos(x,x+31,y,y+20);
    str+=(value-48)*84;
    for(j=0;j<84;j++)
        for(i=0;i<8;i++)
        if((*str&(1<<(7-i)))!=0)
        Write_Data(dcolor>>8,dcolor);
        else
        Write_Data(bgcolor>>8,bgcolor);
    str++;
void Print(unsigned int x,unsigned int y,unsigned char *str,unsigned int dcolor,unsigned int bgcolor)
 unsigned int x1,y1;
    y1=y;
    x1=x;
        while(*str!='\0')
    GotoXY (x1,y1,*str,dcolor,bgcolor);
        y1+=30;
    str++;
    GPIO_SetBits(PORT, GPIO_Pin_9);//RS=1;
    GPIO_ResetBits(REST, GPIO_Pin_1);//CS=0;
    // =x;
    GPIO_ResetBits(PORT, GPIO_Pin_8);//_WR=0;
    GPIO_SetBits(PORT, GPIO_Pin_8);//_WR=1;
    GPIO_SetBits(REST, GPIO_Pin_1);//CS=1;
     GPIO_ResetBits(PORT, GPIO_Pin_9);//RS=0;
    // =DL;
    // =DH;
    // =DL;
 // Configure PB0~PB7 ----------------------------------
  //                            DB0-DB7 lcd data
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        GPIO_StructInit(&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1|GPIO_Pin_2 | GPIO_Pin_3|GPIO_Pin_4 | GPIO_Pin_5|GPIO_Pin_6 |
GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//GPIO_Mode_Out_OD;
        GPIO_Init(PORT, &GPIO_InitStructure);
        //GPIO_Write(PORT, _WR  | RS  | (0xFF << B0));
//      C portu------------------
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 ;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
        GPIO_Init(REST, &GPIO_InitStructure);
int main(void)
    LCD_InitializePorts();
    LCD_Initial();
        Print(100,90,"0123456789",0xffff,0x0054);
        while(1)
//************************************font. h**********************************************************************
#ifndef TM_FONTS_H
#define TM_FONTS_H
unsigned char font1[]={
    //32 pisel
    0x00, 0x00, 0x00, 0x00, //  0
    0x7F, 0xF8, 0x7F, 0xFC, //
    0xBF, 0xFC, 0xFF, 0xFA, //
    0xDF, 0xFC, 0x7F, 0xF6, //
    0xEF, 0xF8, 0x7F, 0xEE, //
    0xF3, 0xF0, 0x3F, 0xDE, //
    0xF8, 0x00, 0x00, 0x3E, //
    0xF3, 0xF0, 0x3F, 0x9E, //
    0xE7, 0xF8, 0x7F, 0xCE, //
    0xCF, 0xFC, 0x7F, 0xE6, //
    0x9F, 0xFC, 0xFF, 0xF2, //
    0x3F, 0xF8, 0x7F, 0xFC, //
    0x00, 0x00,0x00, 0x00,
    0x00, 0x00, 0x00, 0x00,// 1
    0x07, 0xF0, 0x1F, 0xC0,//
    0x0F, 0xF8, 0x3F, 0xE0,//
    0x1F, 0xF8, 0x7F, 0xF0,//
    0x3F, 0xFC, 0xFF, 0xF8,//
    0x7F, 0xF8, 0x7F, 0xFC,//
    0x00, 0x00, 0x00, 0x00, //  2
    0x7F, 0xFC, 0x00, 0x00, //
    0xBF, 0xFE, 0x00, 0x02, //
    0xDF, 0xFC, 0x00, 0x06, //
    0xEF, 0xFF, 0x80, 0x0E, //
    0xF3, 0xFF, 0xC0, 0x1E, //
    0xF8, 0x07, 0xC0, 0x3E, //
    0xF0, 0x03, 0xBF, 0x9E, //
    0xE0, 0x01, 0x7F, 0xCE, //
    0xC0, 0x00, 0xFF, 0xE6, //
    0x80, 0x00, 0xFF, 0xF2, //
    0x00, 0x00, 0x7F, 0xFC, //
    0x00, 0x00, 0x00, 0x00, //  3
    0x80, 0x00, 0x00, 0x02, //
    0xC0, 0x00, 0x00, 0x06, //
    0xE0, 0x03, 0x80, 0x0E, //
    0xF0, 0x07, 0xC0, 0x1E, //
    0xFB, 0xF7, 0xFF, 0xBE, //
    0xE7, 0xFB, 0xFF, 0xCE, //
    0xCF, 0xFD, 0x7F, 0xE6, //
    0x3F, 0xF8, 0x7F, 0xF8, //
    0x00, 0x00, 0x00, 0x00, //  4
    0x00, 0x00, 0xFF, 0xF8, //
    0x00, 0x00, 0x7F, 0xF0, //
    0x00, 0x03, 0xBF, 0xE0, //
    0x00, 0x07, 0xDF, 0xC0, //
    0x00, 0x07, 0xC0, 0x00, //
    0x07, 0xF3, 0xBF, 0xC0, //
    0x0F, 0xF9, 0x3F, 0xC0, //
    0x1F, 0xF8, 0x7F, 0xE0, //
    0x3F, 0xFC, 0xFF, 0xF0, //
    0x7F, 0xF8, 0x7F, 0xF8, //
    0x00, 0x00, 0x00, 0x00, //  5
    0x80, 0x00, 0xFF, 0xFA, //
    0xC0, 0x00, 0xFF, 0xF6, //
    0xE0, 0x03, 0xFF, 0xEE, //
    0xF0, 0x07, 0xFF, 0xDE, //
    0xF3, 0xFB, 0x80, 0x1E, //
    0xE7, 0xFD, 0x00, 0x0E, //
    0xCF, 0xFE, 0x00, 0x06, //
    0x9F, 0xFE, 0x00, 0x02, //
    0x3F, 0xFC, 0x00, 0x00, //
    0x00, 0x00, 0x00, 0x00, //  6
    0xEF, 0xFB, 0xFF, 0xEE, //
    0xF3, 0xF7, 0xFF, 0xDE, //
    0xF3, 0xF3, 0x80, 0x1E, //
    0xE7, 0xF9, 0x00, 0x0E, //
    0xCF, 0xFC, 0x00, 0x06, //
    0x9F, 0xFC, 0x00, 0x02, //
    0x3F, 0xF8, 0x00, 0x00, //
    0x00, 0x00, 0x00, 0x00, //  7
    0x00, 0x00, 0x00, 0x02, //
    0x00, 0x00, 0x00, 0x06, //
    0x00, 0x00, 0x00, 0x0E, //
    0x00, 0x00, 0x00, 0x1E, //
    0x00, 0x00, 0x00, 0x3E, //
    0x07, 0xF0, 0x3F, 0xBE, //
    0x0F, 0xF8, 0x7F, 0xCE, //
    0x1F, 0xF8, 0x7F, 0xE6, //
    0x3F, 0xFC, 0xFF, 0xF2, //
    0x00, 0x00, 0x00, 0x00, //  8
    0xF3, 0xF3, 0xBF, 0x9E, //
    0xE7, 0xF9, 0x7F, 0xCE, //
    0x00, 0x00, 0x00, 0x00, //  9
    0xC0, 0x00, 0x7F, 0xF6, //
#endif
src\main.c||In function 'main':|
src\main.c|248|warning: pointer targets in passing argument 3 of 'Print' differ in signedness [-Wpointer-sign]|
src\main.c|161|note: expected 'unsigned char *' but argument is of type 'char *'|
bin\Debug\sa.map|1|Program size (bytes):    3764|
||Data size    (bytes):     948|
||BSS size     (bytes):      32|
||Total size   (bytes):    4744   (R/W Memory: 980)|
||=== Build finished: 0 errors, 1 warnings (0 minutes, 3 seconds) ===|
