Does the stm32f417 have cache capability? Is it disabled by default?
Question asked by de.sa on Jan 20, 2015
Latest reply on Jan 20, 2015 by Clive One
According to the datasheet it says, cache is turned off and art accelerator is on.
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00035129.pdf
So by default the cache is turned off unless the mpu is programmed according to the memory regions given in the datasheet.
Since, if cache is present and used, it might take less number of cycles to complete a certain set  of instructions in function which are repeating.
