Changing Clock Frequency on STM32F4xx
Question asked by g.martin on Jan 10, 2015
Latest reply on Jan 20, 2015 by g.martin
Having trouble changing the STM32F4 clock (M4 clock) on the fly, dynamically.  When I do, the target fails, sometimes not right away, but within a few dozen seconds.  How do I know its failing?  I have a task attached to a button, that toggles LEDs.  When I change the clock frequency, I push the button, and eventually the LEDs no longer toggle.  The UART debug interface dies right away - note that when I change frequencies, I keep the peripheral bus at the same frequency.  GDB shows the target is stuck in a task that was sending chars out the UART...
Using:
   FreeRTOS ver 8.1.2.
   STM32F439
STM32Cube generates the following code for setting the clock on power up,
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSICalibrationValue = 6;
RCC_OscInitStruct.PLL.PLLM = 8;
RCC_OscInitStruct.PLL.PLLN = 192;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV8;
RCC_OscInitStruct.PLL.PLLQ = 4;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0);
This works fine.  I can use Cube32 to select other clock frequencies and they also work, when run at power up.
The dynamic switching code looks like this,
case POWMAN_LOW:   // 12MHz
    break;
case POWMAN_MED:  // 48MHz
    RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1
                                |RCC_CLOCKTYPE_PCLK2;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV4;
    HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
    break;
I have reviewed the RCC examples for the STM32F4, read the Power Modes app note, read the HAL library documentation, etc...
I am not sure if this is a FreeRTOS issue, or if I am using HAL the wrong way....?
