The example of EEPROM Emulation doesn't work
Question asked by fairchild.brian on Nov 26, 2014
Hi folk
I'm working on the example of EEPROM Emulation that I have downloaded here:
http://www.st.com/web/en/catalog/tools/PF257846
the main.c is this:
  * @file    EEPROM_Emulation/src/main.c
  * @author  MCD Application Team
  * @version V3.1.0
  * @date    07/27/2009
  * @brief   Main program body
  * @copy
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
/** @addtogroup EEPROM_Emulation
#include "eeprom.h"
ErrorStatus  HSEStartUpStatus;
FLASH_Status FlashStatus;
uint16_t VarValue = 0;
/* Virtual address defined by the user: 0xFFFF value is prohibited */
uint16_t VirtAddVarTab[NumbOfVar] = {0x5555, 0x6666, 0x7777};
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  /* Setup STM32 system (clock, PLL and Flash configuration) */
  SystemInit();
  /* Unlock the Flash Program Erase controller */
  FLASH_Unlock();
  /* EEPROM Init */
  EE_Init();
/* --- Store successively many values of the three variables in the EEPROM ---*/
  /* Store 1000 values of Variable1 in EEPROM */
  for (VarValue = 0; VarValue < 1000; VarValue++)
    EE_WriteVariable(VirtAddVarTab[0], VarValue);
  /* Store 500 values of Variable2 in EEPROM */
  for (VarValue = 0; VarValue < 500; VarValue++)
    EE_WriteVariable(VirtAddVarTab[1], VarValue);
  /* Store 800 values of Variable3 in EEPROM */
  for (VarValue = 0; VarValue < 800; VarValue++)
    EE_WriteVariable(VirtAddVarTab[2], VarValue);
  while (1);
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
the eeprom.h  is this:
  * @file    EEPROM_Emulation/inc/eeprom.h
  * @version V3.1.0
  * @date    07/27/2009
  * @brief   This file contains all the functions prototypes for the EEPROM
  *          emulation firmware library.
  * @copy
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __EEPROM_H
#define __EEPROM_H
#include "stm32f10x.h"
/* Exported constants --------------------------------------------------------*/
/* Define the STM32F10Xxx Flash page size depending on the used STM32 device */
#if defined (STM32F10X_LD) || defined (STM32F10X_MD)
  #define PAGE_SIZE  (uint16_t)0x400  /* Page size = 1KByte */
#elif defined (STM32F10X_HD) || defined (STM32F10X_CL)
  #define PAGE_SIZE  (uint16_t)0x800  /* Page size = 2KByte */
#endif
/* EEPROM start address in Flash */
#define EEPROM_START_ADDRESS    ((uint32_t)0x08010000) /* EEPROM emulation start address:
                                                  after 64KByte of used Flash memory */
/* Pages 0 and 1 base and end addresses */
#define PAGE0_BASE_ADDRESS      ((uint32_t)(EEPROM_START_ADDRESS + 0x000))
#define PAGE0_END_ADDRESS       ((uint32_t)(EEPROM_START_ADDRESS + (PAGE_SIZE - 1)))
#define PAGE1_BASE_ADDRESS      ((uint32_t)(EEPROM_START_ADDRESS + PAGE_SIZE))
#define PAGE1_END_ADDRESS       ((uint32_t)(EEPROM_START_ADDRESS + (2 * PAGE_SIZE - 1)))
/* Used Flash pages for EEPROM emulation */
#define PAGE0                   ((uint16_t)0x0000)
#define PAGE1                   ((uint16_t)0x0001)
/* No valid page define */
#define NO_VALID_PAGE           ((uint16_t)0x00AB)
/* Page status definitions */
#define ERASED                  ((uint16_t)0xFFFF)     /* PAGE is empty */
#define RECEIVE_DATA            ((uint16_t)0xEEEE)     /* PAGE is marked to receive data */
#define VALID_PAGE              ((uint16_t)0x0000)     /* PAGE containing valid data */
/* Valid pages in read and write defines */
#define READ_FROM_VALID_PAGE    ((uint8_t)0x00)
#define WRITE_IN_VALID_PAGE     ((uint8_t)0x01)
/* Page full define */
#define PAGE_FULL               ((uint8_t)0x80)
/* Variables' number */
#define NumbOfVar               ((uint8_t)0x03)
/* Exported types ------------------------------------------------------------*/
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
uint16_t EE_Init(void);
uint16_t EE_ReadVariable(uint16_t VirtAddress, uint16_t* Data);
uint16_t EE_WriteVariable(uint16_t VirtAddress, uint16_t Data);
#endif /* __EEPROM_H */
As you can see, the EEPROM start address in Flash is:
#define EEPROM_START_ADDRESS    ((uint32_t)0x08010000) /* EEPROM emulation start address: after 64KByte of used Flash memory */
then 0x08010000 is the start address. after compiling the program and downloading it,
I execute it in debug and even without debugger but after I referred to 0x08010000 of the flash memory (by reading the flash memory through debugger), I just can see: FFFFFFFF....
where am I wrong?
