Unable to read ADC on a STM32F302
Question asked by ebommer on Sep 25, 2014
Latest reply on Oct 2, 2014 by Montassar BEN ROMDHANE
I am trying to read several A/D channels.  I have stepped through the code but so far I am reading the same values for all of the A/D’s (Even though I have different voltage levels on 3 on the pins).  Looking at the “DR” register I am seeing values around 0x0f and I was expecting values much higher on the 3 channels (1.5 to 3 volts) I have voltage on. Also looking at the registers I don’t see any of the channels for ADC2 listed in the “ADCx_SQR”.  I am assuming I am missing something in my configuration.
__IO uint16_t uhADCxConvertedValue[12];
int main(void)
unsigned int   TempIndex;
  HAL_Init();   // ST Library
  SystemClock_Config();
  /* System interrupt init*/
  /* Sets the priority grouping field */
  HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_0);
  MX_GPIO_Init();
  MX_ADC1_Init();
  MX_ADC2_Init();
  HAL_ADCEx_Calibration_Start(&hadc1,ADC_SINGLE_ENDED);
  while (1)
    for(TempIndex =1;TempIndex <=7; TempIndex++)
        hadc1.NbrOfConversionRank = TempIndex;
        HAL_ADC_Start(&hadc1);
        HAL_ADC_PollForConversion(&hadc1, 100);
        if(HAL_ADC_GetState(&hadc1) == HAL_ADC_STATE_EOC_REG)
            uhADCxConvertedValue[TempIndex] = HAL_ADC_GetValue(&hadc1);
            TempIndex =TempIndex;
        HAL_ADC_Stop(&hadc1);
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_I2C1
                              |RCC_PERIPHCLK_ADC12;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
  PeriphClkInit.Adc12ClockSelection = RCC_ADC12PLLCLK_DIV1;
  PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_SYSCLK;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
  HAL_RCC_EnableCSS();
  __SYSCFG_CLK_ENABLE();
void MX_GPIO_Init(void)
  /* GPIO Ports Clock Enable */
  __GPIOE_CLK_ENABLE();
  __GPIOC_CLK_ENABLE();
  __GPIOF_CLK_ENABLE();
  __GPIOA_CLK_ENABLE();
  __GPIOB_CLK_ENABLE();
  __GPIOD_CLK_ENABLE();
  /*Configure GPIO pins : PE2 PE3 PE4 PE5
                           PE6 */
  GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5
                          |GPIO_PIN_6;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pins : PC13 PC12 */
  GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_12;
  /*Configure GPIO pins : PB10 PB13 PB14 PB15 */
  GPIO_InitStruct.Pin = GPIO_PIN_10|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  /*Configure GPIO pin : PB12 */
  GPIO_InitStruct.Pin = GPIO_PIN_12;
  GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
  /*Configure GPIO pins : PD8 PD9 PD10 PD0
                           PD1 PD2 */
  GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_0
                          |GPIO_PIN_1|GPIO_PIN_2;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pins : PD12 PD13 PD14 PD15 */
  GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  /*Configure GPIO pins : PC6 PC7 PC8 PC9 */
  GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9;
  /*Configure GPIO pin : PA8 */
  GPIO_InitStruct.Pin = GPIO_PIN_8;
  /*Configure GPIO pin : PA9 */
  GPIO_InitStruct.Pin = GPIO_PIN_9;
void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig;
    /**Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC;
  hadc1.Init.Resolution = ADC_RESOLUTION12b;
  hadc1.Init.ScanConvMode = DISABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.NbrOfDiscConversion = 1;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 7;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.EOCSelection = EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.Overrun = OVR_DATA_OVERWRITTEN;
  HAL_ADC_Init(&hadc1);
    /**Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = 1;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.SamplingTime = ADC_SAMPLETIME_61CYCLES_5;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  HAL_ADC_ConfigChannel(&hadc1, &sConfig);
  sConfig.Channel = ADC_CHANNEL_2;
  sConfig.Rank = 2;
  sConfig.Channel = ADC_CHANNEL_3;
  sConfig.Rank = 3;
  sConfig.Channel = ADC_CHANNEL_4;
  sConfig.Rank = 4;
  sConfig.Channel = ADC_CHANNEL_5;
  sConfig.Rank = 5;
  sConfig.Channel = ADC_CHANNEL_6;
  sConfig.Rank = 6;
  sConfig.Channel = ADC_CHANNEL_8;
  sConfig.Rank = 7;
/* ADC2 init function */
void MX_ADC2_Init(void)
    /**Common config
  hadc2.Instance = ADC2;
  hadc2.Init.ClockPrescaler = ADC_CLOCK_ASYNC;
  hadc2.Init.Resolution = ADC_RESOLUTION12b;
  hadc2.Init.ScanConvMode = DISABLE;
  hadc2.Init.ContinuousConvMode = ENABLE;
  hadc2.Init.DiscontinuousConvMode = DISABLE;
  hadc2.Init.NbrOfDiscConversion = 1;
  hadc2.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc2.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc2.Init.NbrOfConversion = 4;
  hadc2.Init.DMAContinuousRequests = DISABLE;
  hadc2.Init.EOCSelection = EOC_SINGLE_CONV;
  hadc2.Init.LowPowerAutoWait = DISABLE;
  hadc2.Init.Overrun = OVR_DATA_OVERWRITTEN;
  HAL_ADC_Init(&hadc2);
  sConfig.Channel = ADC_CHANNEL_7;
  sConfig.Rank = 1;
  sConfig.Offset = 0;
  HAL_ADC_ConfigChannel(&hadc2, &sConfig);
  sConfig.Channel = ADC_CHANNEL_9;
  sConfig.Rank = 2;
  sConfig.Channel = ADC_CHANNEL_10;
  sConfig.Rank = 3;
  sConfig.Channel = ADC_CHANNEL_11;
  sConfig.Rank = 4;
static int ADC12_CLK_ENABLED=0;
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
  if(hadc->Instance==ADC1)
    /* Peripheral clock enable */
    ADC12_CLK_ENABLED++;
    if(ADC12_CLK_ENABLED==1){
      __ADC12_CLK_ENABLE();
    /**ADC1 GPIO Configuration
    PC0     ------> ADC1_IN6
    PC2     ------> ADC1_IN8
    PA0     ------> ADC1_IN1
    PA1     ------> ADC1_IN2
    PA2     ------> ADC1_IN3
    PA3     ------> ADC1_IN4
    PF4     ------> ADC1_IN5
    GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_2;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2;
    GPIO_InitStruct.Pin = GPIO_PIN_4;
    HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  else if(hadc->Instance==ADC2)
    /**ADC2 GPIO Configuration
    PC1     ------> ADC2_IN7
    PC3     ------> ADC2_IN9
    PF2     ------> ADC2_IN10
    PC5     ------> ADC2_IN11
    GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_3|GPIO_PIN_5;
    GPIO_InitStruct.Pin = GPIO_PIN_2;
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* hadc)
    /* Peripheral clock disable */
    ADC12_CLK_ENABLED--;
    if(ADC12_CLK_ENABLED==0){
      __ADC12_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOC, GPIO_PIN_0|GPIO_PIN_2);
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2);
    HAL_GPIO_DeInit(GPIOF, GPIO_PIN_4);
    HAL_GPIO_DeInit(GPIOC, GPIO_PIN_1|GPIO_PIN_3|GPIO_PIN_5);
    HAL_GPIO_DeInit(GPIOF, GPIO_PIN_2);
