Acquisition in nine analog channels using the ADC1, ADC2 and ADC3 with DMA.
Question asked by mata.paulo on Sep 1, 2014
Latest reply on Sep 1, 2014 by mata.paulo
Hello everyone,
I need to read nine analog channels, so I'm using the ADC1, ADC2 and ADC3 with DMA. However only three channels is working for just one ADC. Follows the code, please someone give me a hint where I am going wrong or suggestions. From already thank you very much.
#define ADC1_DR_ADDRESS    ((uint32_t)0x4001204C)
#define ADC2_DR_ADDRESS    ((uint32_t)0x4001214c)
#define ADC3_DR_ADDRESS    ((uint32_t)0x4001224C)
__IO uint16_t ADCConvertedValue1[3] = {0,0,0};
__IO uint16_t ADCConvertedValue2[3] = {0,0,0};
__IO uint16_t ADCConvertedValue3[3] = {0,0,0};
__IO uint16_t val1=0, val2=0, val3=0, val4=0, val5=0, val6=0, val7=0, val8=0, val9=0;
  ADC_InitTypeDef       ADC_InitStructure;
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  DMA_InitTypeDef       DMA_InitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
void ADC1_DMA_Config(void);
void ADC2_DMA_Config(void);
void ADC3_DMA_Config(void);
int main(void)
  ADC1_DMA_Config();
  ADC2_DMA_Config();
  ADC3_DMA_Config();
  /* Start ADC Software Conversion */
   ADC_SoftwareStartConv(ADC1);
  ADC_SoftwareStartConv(ADC2);
  ADC_SoftwareStartConv(ADC3);
  while (1)
  /* convert the ADC value (from 0 to 0xFFF) to a voltage value (from 0V to 3.3V)*/
val1=ADCConvertedValue1[0]*3000/0xFFF;
val2=ADCConvertedValue1[1]*3000/0xFFF;
val3=ADCConvertedValue1[2]*3000/0xFFF;
val4=ADCConvertedValue2[0]*3000/0xFFF;
val5=ADCConvertedValue2[1]*3000/0xFFF;
val6=ADCConvertedValue2[2]*3000/0xFFF;
val7=ADCConvertedValue3[0]*3000/0xFFF;
val8=ADCConvertedValue3[1]*3000/0xFFF;
val9=ADCConvertedValue3[2]*3000/0xFFF;
  // Enable ADC, DMA2 and GPIO clocks ****************************************
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2|RCC_AHB1Periph_GPIOC, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  // DMA2 Stream0 channel0 configuration **************************************
  DMA_InitStructure.DMA_Channel =DMA_Channel_0;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADCConvertedValue1;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = 3;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
  // Configure ADC Channel pin as analog input ******************************
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 |GPIO_Pin_4|GPIO_Pin_5;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  // ADC Common Init **********************************************************
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
  // ADC Init ****************************************************************
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  ADC_InitStructure.ADC_NbrOfConversion = 3;
  ADC_Init(ADC1, &ADC_InitStructure);
  // ADC regular channel configuration *************************************
  ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 1, ADC_SampleTime_3Cycles);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 2, ADC_SampleTime_3Cycles);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 3, ADC_SampleTime_3Cycles);
  // Enable DMA request after last transfer (Single-ADC mode)
  ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
  // Enable ADC DMA
  ADC_DMACmd(ADC1, ENABLE);
  // Enable ADC
  ADC_Cmd(ADC1, ENABLE);
     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2|RCC_AHB1Periph_GPIOC|RCC_AHB1Periph_GPIOB, ENABLE);
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);
  DMA_InitStructure.DMA_Channel =DMA_Channel_1;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC2_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADCConvertedValue2;
  DMA_Init(DMA2_Stream2, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream2, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 |GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  ADC_Init(ADC2, &ADC_InitStructure);
  ADC_RegularChannelConfig(ADC2, ADC_Channel_8, 4, ADC_SampleTime_3Cycles);
  ADC_RegularChannelConfig(ADC2, ADC_Channel_9, 5, ADC_SampleTime_3Cycles);
  ADC_RegularChannelConfig(ADC2, ADC_Channel_11, 6, ADC_SampleTime_3Cycles);
  ADC_DMARequestAfterLastTransferCmd(ADC2, ENABLE);
  // Enable ADC DMA
     ADC_DMACmd(ADC2, ENABLE);
  // Enable ADC
     ADC_Cmd(ADC2, ENABLE);
  // Enable ADC3, DMA2 and GPIO clocks ****************************************
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2|RCC_AHB1Periph_GPIOA, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
  DMA_InitStructure.DMA_Channel =DMA_Channel_2;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC3_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADCConvertedValue3;
  DMA_Init(DMA2_Stream1, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream1, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 |GPIO_Pin_2 |GPIO_Pin_3;
  ADC_Init(ADC3, &ADC_InitStructure);
  ADC_RegularChannelConfig(ADC3, ADC_Channel_1, 7, ADC_SampleTime_3Cycles);
  ADC_RegularChannelConfig(ADC3, ADC_Channel_2, 8, ADC_SampleTime_3Cycles);
  ADC_RegularChannelConfig(ADC3, ADC_Channel_3, 9, ADC_SampleTime_3Cycles);
     ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE);
  // Enable ADC DMA
     ADC_DMACmd(ADC3, ENABLE);
  // Enable ADC
     ADC_Cmd(ADC3, ENABLE);
