Check that the device is erased before programming
Question asked by li.roy on Jul 3, 2014
Latest reply on Jul 4, 2014 by Brutte
I  program the chip with STVP_CmdLine.exe, and found strange thing:
The log says that "Erasing PROGRAM MEMORY succeeds" and then failed with message "Check that the device is erased before programming", it seems that the STLink
did not really erasing the memory when it log the message.
The strange things are:
I run successed yesterday with same script, but could not pass today. (ON Winxp)
stvp can program the chip successfully.
Any clue are very welcome.
Below is the log:
            new log session
            date:    07/03/14
            time:    10:29:08
            STVP_CmdLine version 1.6
Verbose ON
            Log activity ON
            Display Progress OFF
            Message box warning if protect option byte OFF
            Loop mode OFF
            Erase device ON
            Blank check device OFF
            Verify device ON
Configuration:
            BoardName=ST-LINK ST-LINK_ID=0 Device=STM32F030x8 Port=USB ProgMode=SWD
>>> Filling PROGRAM MEMORY image in computer with Blank Value
            <<< Filling PROGRAM MEMORY image in computer succeeds
>>> Loading file C:\Documents and Settings\Administrator\桌面\0703测试hex\单相表SL500Swarm_R.hex in PROGRAM MEMORY image in computer
            <<< Loading file succeeds
>>> Loading file D:\Program Files\Neoway\FactoryAssistant\STLink\\opt_protect.hex in OPTION BYTE image in computer
            Warning: Old ST-Link firmware version detected.
            You can update the ST-Link firmware with ST-LinkUpgrade.exe utility and reboot the ST-Link with USB cable.
              Mass Erasing device...
              Blank Checking device...
<<< Erasing PROGRAM MEMORY succeeds
>>> Programming PROGRAM MEMORY
            Programming failed. Check that the device is erased before programming
            <<< Programming PROGRAM MEMORY fails
