TIM3 Issue in STM32F215
Question asked by p.thirukkannan on Jun 5, 2014
Latest reply on Jun 26, 2014 by Clive One
I am using TIM3(PC6 to PC9) for PWM output in STM32F215.
In this I want three 50Hz PWM signals and one 8KHz signal. So I have configured PC7,PC8,PC9 as 50Hz PWM  signals. For this i have assigned PrescalerValue_50 = (uint16_t) ((SystemCoreClock/2 ) / 33335) - 1; And I have configured PC6 as 80KHz PWM signal.For this i have assigned PrescalerValue_10 = (uint16_t) ((SystemCoreClock/2 ) / 5000000) - 1; But i am getting 8KHz in all pins. What is problem i do'nt know. Please help me asap. Below is my code
void TIM_Config(void)
    /* TIM3 clock enable */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
    /* GPIOC clock enable */
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
    /* GPIOC Configuration: TIM3 CH1 (PC6), TIM3 CH2 (PC7), TIM3 CH3 (PC8) and TIM3 CH4 (PC9) */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
    /* Connect TIM3 pins to AF2 */
    //GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_TIM3);
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_TIM3);
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_TIM3);
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource9, GPIO_AF_TIM3);
    /* Compute the prescaler value */
    /* Time base configuration */
    TIM_TimeBaseStructure.TIM_Period = 665;
    TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue_50;
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
    /* PWM1 Mode configuration: Channel1 */
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
void TIM_Cong1(uint16_t Dutycycle)
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
    TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue_10;
//    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = Dutycycle;
    TIM_OC1Init(TIM3, &TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
    TIM_ARRPreloadConfig(TIM3, ENABLE);
    TIM_Cmd(TIM3, ENABLE);
void PWM_Generation1(uint16_t Dutycycle)
    TIM_OC4Init(TIM3, &TIM_OCInitStructure);
    TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
//    TIM_ARRPreloadConfig(TIM3, ENABLE);
void PWM_Generation2(uint16_t Dutycycle)
    TIM_OC3Init(TIM3, &TIM_OCInitStructure);
    TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
void PWM_Generation3(uint16_t Dutycycle)
    TIM_OC2Init(TIM3, &TIM_OCInitStructure);
    TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
Thirukkannan.
