Help CubeMX HAL and DMA2D
Question asked by christian on Apr 3, 2014
Latest reply on Jun 6, 2014 by Montassar BEN ROMDHANE
Hi.
Help is needed for Alpha channel input (CM_A4 an CM_A8) in combination with the HAL_DMA2D_BlendingStart(...) of the CubeMX HAL.
It seems like FGCOLR is not set neither with the call nor with Dma2dHandle.LayerCfg.
Furthermore the entire blending process is not clear to me. How to select / unselect the foreground layer, background layer and background color. What is needed for a simple CM_A4 + Color -> RGB transformation. A code snippet or similar would be great.
Thanks in advance.
