stm32f405 malloc issue
Question asked by Angelo Dureghello on Mar 31, 2014
Latest reply on Mar 31, 2014 by sung.chen_chung
Dear,
as in several examples, i implemented my _sbrk function to be able to use malloc, as (copied from examples):
extern int  _end;
 * _sbrk needed for malloc
caddr_t _sbrk ( int incr ) {
        static unsigned char *heap = NULL;
        unsigned char *prev_heap;
        if (heap == NULL) {
                heap = (unsigned char *)&_end;
        prev_heap = heap;
        /* check removed to show basic approach */
        heap += incr;
        return (caddr_t) prev_heap;
Program compiles fine, no warnings, if i call directly _sbrk to allocate memory (instead of malloc) it works perfect, if i instead call "malloc", i see that _sbrk is called, but the return value of malloc is an null pointer (0).
Probably, malloc after calling sbrk do some other checks, and returns 0.
Every help is appreciated.
