Dealing with Timers
Question asked by laaroussi.salah on Feb 21, 2014
Latest reply on Jun 9, 2014 by nahvi.mohamad
Hi
i'm begginer in STM world, that's y i'm facing Problem in dealing with stm32 TIMer's.
and really i can't understand.y we use TIMers.
that's y i'm dealing with this code below (REALLY i can't understand what i have to put in /*configure TIM7), ALSo there is a an interupt and i can't fill it the right codes to make my pro work
  * @file    Examples/GPIOToggle/main.c
  * @author  MCD Application Team
  * @version V1.0.0
  * @date    09/13/2010
  * @brief   Main program body.
  * @copy
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2010 STMicroelectronics</center></h2>
#include "stm32f10x.h"
#include "stm32f10x_rcc.h"
#include "stm32f10x_gpio.h"
#include "stm32f10x_tim.h"
/** @addtogroup Examples
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
void Delay(__IO uint32_t nCount);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* Configure all unused GPIO port pins in Analog Input mode (floating input
     trigger OFF), this will reduce the power consumption and increase the device
     immunity against EMI/EMC *************************************************/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
                         RCC_APB2Periph_GPIOE, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_Init(GPIOE, &GPIO_InitStructure);
                         RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE,
                         DISABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM7, ENABLE);
  /* Initialize Leds LD3 and LD4 mounted on STM32VLDISCOVERY board */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  /* Configure Timer 7 interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM7_IRQn ;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd =ENABLE;
  /* COnfigure Timer to generate 1ms */
  TIM_TimeBaseStructure.TIM_Period = 1000 - 1;// 1 MHz down to 1 KHz (1 ms)
  TIM_TimeBaseStructure.TIM_Prescaler = 36-1; // 36 MHz Clock down to 1 MHz
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  /* Configure Timer 7*/
 TIM_TimeBaseInit(TIM7, &TIM_TimeBaseStructure);
//TIM7_configuration();
 /* TIM7 IT enable */
TIM_ITConfig(TIM7, TIM_IT_Update, ENABLE);
 /* TIM7 enable counter */
 TIM_Cmd(TIM7, ENABLE);
  while (1)
    /* Turn on LD2 and LD3 */
 GPIO_SetBits(GPIOC,GPIO_Pin_8|GPIO_Pin_9);
     /* Insert delay */
    Delay(0x0FFFF);
    /* Turn off LD3 and LD4 */
GPIO_ResetBits(GPIOC,GPIO_Pin_8|GPIO_Pin_9);
    /* Insert delay */
    Delay(0x0FFFF);
  for(; nCount != 0; nCount--);
  * @brief  Inserts a delay time.
  * @param  nCount: specifies the delay time length.
  * @retval None
//void Delay(__IO uint32_t nCount)
  //for(; nCount != 0; nCount--);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
____________________________________________________________
and this is the "stm32f10x_it.c
  * @file    Examples/GPIOToggle/stm32f10x_it.c
  * @version V1.0.0
  * @date    09/13/2010
  * @brief   Main Interrupt Service Routines.
  *          This file provides template for all exceptions handler and peripherals
  *          interrupt service routine.
  * @copy
#include "stm32f10x_it.h"
/*            Cortex-M3 Processor Exceptions Handlers                         */
  * @brief  This function handles NMI exception.
  * @param  None
  * @retval None
void NMI_Handler(void)
  * @brief  This function handles Hard Fault exception.
  * @param  None
  * @retval None
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
  * @brief  This function handles Memory Manage exception.
  * @param  None
  * @retval None
void MemManage_Handler(void)
  /* Go to infinite loop when Memory Manage exception occurs */
  while (1)
  * @brief  This function handles Bus Fault exception.
  * @param  None
  * @retval None
void BusFault_Handler(void)
  /* Go to infinite loop when Bus Fault exception occurs */
  while (1)
  * @brief  This function handles Usage Fault exception.
  * @param  None
  * @retval None
void UsageFault_Handler(void)
  /* Go to infinite loop when Usage Fault exception occurs */
  while (1)
  * @brief  This function handles SVCall exception.
  * @param  None
  * @retval None
void SVC_Handler(void)
  * @brief  This function handles Debug Monitor exception.
  * @param  None
  * @retval None
void DebugMon_Handler(void)
  * @brief  This function handles PendSV_Handler exception.
  * @param  None
  * @retval None
void PendSV_Handler(void)
  * @brief  This function handles SysTick Handler.
  * @param  None
  * @retval None
void SysTick_Handler(void)
/*                 STM32F10x Peripherals Interrupt Handlers                   */
/*  Add here the Interrupt Handler for the used peripheral(s) (PPP), for the  */
/*  available peripheral interrupt handler's name please refer to the startup */
/*  file (startup_stm32f10x_xx.s).                                            */
  * @brief  This function handles PPP interrupt request.
  * @param  None
  * @retval None
/*void PPP_IRQHandler(void)
void TIM7_IRQHandler(void)
 /* Toggle LED3 */
   GPIO_SetBits(GPIOC,GPIO_Pin_9);
     /* Insert delay */
    Delay(0xAFFFF);
        /* Turn off LD3*/
GPIO_ResetBits(GPIOC,GPIO_Pin_9);
    /* Insert delay */
    Delay(0xAFFFF);
