ADC Not Working
Question asked by be_senyor.ezra on Nov 11, 2010
Latest reply on Nov 14, 2010 by be_senyor.ezra
hi
i am tring to use the ADC but for some reason i dont get the EOC flag.
why?
what am i doing wrong?
thanks.
  * @file    ScanContinuous/src/main.c
  * @author  MCD Application Team
  * @version V1.0.0
  * @date    03/09/2010
  * @brief   Main program body
  * @copy
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2010 STMicroelectronics</center></h2>
#include "stm32f10x.h"
/** @addtogroup ScanContinuous
/* Comment or incomment this define to use or not the DMA */
#define ADC1_DR_Address    ((uint32_t)0x4001244C)
#define BufferLenght       4
ADC_InitTypeDef   ADC_InitStructure;
DMA_InitTypeDef   DMA_InitStructure;
__IO uint16_t ADC1ConvertedValue[BufferLenght];
ErrorStatus HSEStartUpStatus;
void RCC_Configuration(void);
void GPIO_Configuration(void);
  * @param  None
  * @retval None
int b=0;
int main(void)
  /* System clocks configuration ---------------------------------------------*/
  RCC_Configuration();
  /* GPIO configuration ------------------------------------------------------*/
  GPIO_Configuration();
  /* DMA1 channel1 configuration ---------------------------------------------*/
  DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC1ConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = BufferLenght;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  /* Enable DMA1 channel1 */
  DMA_Cmd(DMA1_Channel1, ENABLE);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_NbrOfChannel = BufferLenght;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel11, channel14, channel16 and channel17 configurations */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_41Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_17, 2, ADC_SampleTime_239Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 3, ADC_SampleTime_239Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 4, ADC_SampleTime_1Cycles5);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable TempSensor and Vrefint channels: channel16 and Channel17 */
  ADC_TempSensorVrefintCmd(ENABLE);
  /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  /* Test on Channel 1 DMA1_FLAG_TC flag */
  while(!DMA_GetFlagStatus(DMA1_FLAG_TC1));
  /* Clear Channel 1 DMA1_FLAG_TC flag */
  DMA_ClearFlag(DMA1_FLAG_TC1);
  while (1)
   b= ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC);
  if (b>0)
   GPIOA->ODR=b;
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval None
    /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* ADCCLK = PCLK2/4 */
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);
#ifndef STM32F10X_CL
    /* PLLCLK = 8MHz * 7 = 56 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_7);
#else
    /* Configure PLLs *********************************************************/
    /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
    RCC_PREDIV2Config(RCC_PREDIV2_Div5);
    RCC_PLL2Config(RCC_PLL2Mul_8);
    /* Enable PLL2 */
    RCC_PLL2Cmd(ENABLE);
    /* Wait till PLL2 is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLL2RDY) == RESET)
    /* PLL configuration: PLLCLK = (PLL2 / 5) * 7 = 56 MHz */
    RCC_PREDIV1Config(RCC_PREDIV1_Source_PLL2, RCC_PREDIV1_Div5);
    RCC_PLLConfig(RCC_PLLSource_PREDIV1, RCC_PLLMul_7);
#endif
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
    /* Enable DMA1 clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
/* Enable peripheral clocks --------------------------------------------------*/
  /* Enable ADC1 and GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE);
  * @brief  Configures the different GPIO ports.
  * @param  None
  * @retval None
  /* Configure PC.01 and PC.04 (Channel11 and Channel14) as analog input -----*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
 thanks.
