SPWF01S Test mode
Question asked by manninen.jarno on Oct 18, 2016
Latest reply on Oct 18, 2016 by Gerardo Gallucci
UM1695 mentions that there is a special test mode that is enabled via configuration variable "eft_mode". Description says "Enable/disable the Engineering Test Functions. It is used for controlling the radio for the certification tests (disabled by default=0, enabled=1)".
However I cannot find any more documentation on this. Typically in these tests we would like to select the channel and transmission and jut send some data patterns in order to measure the antenna implementation etc. How are these controlled when test mode is enabled?
