How to update firmware FPWF01SA via OTP?
Question asked by Bortole on Jul 28, 2015
Latest reply on Aug 10, 2015 by Bortole
I am wondering how to update FPWF01SA firmware via OTA? I saw the command in the user manual, but I could not find the ST website to download the firmware. And how is the sequence to upgrade the firmare? Moreover, how can I know the last firmware version available?
One more thing: I am trying to communicate the module over UDP and it is not sending/receiving anything. I am wondering if an firmware upgrade will solve this issue.
I really appreciate any help.
Thanks!
Here is AT&V dump:
# Dumping All Configuration Keys:
#  nv_manuf = ST
#  nv_model = SPWF01SA1
#  nv_serial = 2914D34571
#  nv_wifi_macaddr = 00:80:E1:FF:CC:B4
#  blink_led = 0
#  wind_off_low = 0x00000000
#  wind_off_medium = 0x00000000
#  wind_off_high = 0x00000000
#  user_desc = exo
#  escape_seq = at+s.
#  localecho1 = 0
#  console1_speed = 921600
#  console1_hwfc = 0
#  console1_enabled = 1
#  sleep_enabled = 0
#  standby_enabled = 0
#  standby_time = 10
#  wifi_tx_msdu_lifetime = 0
#  wifi_rx_msdu_lifetime = 0
#  wifi_operational_mode = 0x00000011
#  wifi_beacon_wakeup = 1
#  wifi_beacon_interval = 100
#  wifi_listen_interval = 0
#  wifi_rts_threshold = 3000
#  wifi_ssid = 48:32:43:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_ssid_len = 3
#  wifi_channelnum = 6
#  wifi_opr_rate_mask = 0x00003FCF
#  wifi_bas_rate_mask = 0x0000000F
#  wifi_mode = 3
#  wifi_auth_type = 0
#  wifi_atim_window = 0
#  wifi_powersave = 0
#  wifi_tx_power = 18
#  wifi_rssi_thresh = 0
#  wifi_rssi_hyst = 0
#  wifi_ap_idle_timeout = 15000
#  wifi_beacon_loss_thresh = 10
#  wifi_priv_mode = 0
#  wifi_wep_keys[0] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[1] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[2] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[3] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_key_lens = 00:00:00:00
#  wifi_wep_default_key = 0
#  wifi_wpa_psk_raw = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wpa_psk_text =
#  ip_use_dhcp = 2
#  ip_use_httpd = 0
#  ip_mtu = 1500
#  ip_hostname = H2C
#  ip_apdomainname = captiveportal.net
#  ip_ipaddr = 192.168.1.1
#  ip_netmask = 255.255.255.0
#  ip_gw = 192.168.1.1
#  ip_dns = 192.168.1.1
#  ip_http_get_recv_timeout = 3000
#  ip_dhcp_timeout = 20
