ST95HF Error Codes
Question asked by Olivjer on Oct 19, 2015
Latest reply on Nov 17, 2015 by NFC IC support2
Hi Guys,
I got problems in the calibration-process (same routine like in the ST95HF Eval Firmware). I should get Responses of the ST95HF like "0x00 0x01 0x01" or "0x00 0x01 0x02" to get the DAC Data High border. But instead the Repsonses I should get, I get "0x00 0x01 0x80". The Datasheet says something like that to the Error Code 0x80:
EFrameRecvOK
Frame correctly received (additionally see
CRC/Parity information)
But that really doesn't help me. I also get sometimes the Error Code 0x82.
Is there an application note, which recommends what o do with the different error codes?
Thanks a lot!
