help - most simple way for ADC - STM32F103
Question asked by karakaya.mehmet on Nov 25, 2013
Latest reply on Nov 25, 2013 by Clive One
hello dear forum,
( STM32F103 )
I am trying to measure 5 analog signal with most simple way
I am taking 10 consecutive ADC result and take their avarage
however I have trouble with ADC , the measurements are wrong
sometimes the ADC "get stuck" with a fake value sometimes it measures wrong value
btw  I am measuring 5 analog channels, I showed 2 of them below beouse the idea is the same
have a look at my code and please advise
int16_t averhold[5][20];
void ADCinit(void){
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
/* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
/* ADC1 regular channels configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_28Cycles5);
  /* Regular discontinuous mode channel number configuration */
  ADC_DiscModeChannelCountConfig(ADC1, 1);
  /* Enable regular discontinuous mode */
  ADC_DiscModeCmd(ADC1, ENABLE);
  /* Enable ADC1 external trigger conversion */
  ADC_ExternalTrigConvCmd(ADC1, ENABLE);
  /* Set injected sequencer length */
  /* ADC1 injected channel configuration */
  /* ADC1 injected external trigger configuration */
  /* Enable ADC1 injected external trigger conversion */
  /* Enable JEOC interupt */
//  ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
  /* Enable ADC1 DMA */
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
here is the measurement block
void GetADCRes(void){
int16_t *RAMptr ;
int8_t avi;//avi2;
int32_t avertotal=0;
            ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 1, ADC_SampleTime_28Cycles5);
            for (avi=0;avi<10;avi++){
            ADC_SoftwareStartConvCmd(ADC1, ENABLE);
            while (ADC_GetSoftwareStartConvStatus(ADC1));
            Delay(20);
            RAMptr= &averhold[0][avi];
            *RAMptr= ADC_GetConversionValue(ADC1);
        avertotal=0;
        for (avi=0; avi<10; avi++)  avertotal += averhold[0][avi];
        RAMptr=&RAM[PARAMETERS + 100*2 ];
        *RAMptr= avertotal / 10;
            Delay(20);
            RAMptr= &averhold[1][avi];
        avertotal=0;
        for (avi=0; avi<10; avi++)  avertotal += averhold[1][avi];
        RAMptr=&RAM[PARAMETERS + 101*2 ];
what I want to ask is , is this measurement code correct ?
Delay(20);
this rank , should it be different for every channel ? I am taking it "1" for every channel
void ADC_RegularChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime)
thank you
