STM32F205 and USB virtual com port problem
Question asked by donev.georgi on Aug 13, 2013
Latest reply on Aug 20, 2013 by donev.georgi
 Hi all,
 I'm using STM32F205VGT,STM32_USB-Host-Device_Lib_V2.1.0 and virtual com port driver "VCP_V1.3.1_Setup_x64.exe". The PC works with Windows 7/64bits. When I start USB device the initialization of USB starts correct and everything works OK. I can see this in debug terminal:
1)
  USB Init...
 USB OTG FS VCP Device
 USB device library started.
  USB Device [FS] Reset....
  VCP Interface configured
 Then I unplug USB cable and this message appears:
  USB Device in Suspend Mode.
  And USB enter in Suspend Mode. After that I plug USB cable again:
 And everything works fine. But when I try to connect USB of another computer this strange situation appears:
2)
  And PC cannot find the usb device. I tried to connect USB device to different computers and in some cases USB work fine but sometimes it doesn't work and  situation 2 appears. I examined the USB code and noticed that in situattion 2 the program doesn't enter in function DCD_HandleSof_ISR(); so I suppose that because the function  is not called therefore USB device enters in Suspend mode again. But I cannot find out why it happens,in some cases SOF appers but in sometimes it doesn't.
Has anybody got any idea? Thanks!
