Timer1 Up to 4 independent channels (Mine is Opposite!)
Question asked by slimsly on Aug 4, 2013
Latest reply on Aug 4, 2013 by slimsly
I am experiencing unusual circumstance with stm32f103rb  Timer1 configure as PWM on all 4 channel.CH1--CH3 complimentary output is enable with dead-time.I have a code that function well when Tim4 CH4 interrupt is absent (As seen in screen_1).
I plan to trigger ADC in Tim4 CH4 ISR. the code malfunction when I enable Tim4 CH4 interrupt ( as seen in screen_2 below). The CH1..CH3  and it complimentary output trigger spuriously.it also stop Timer3 counter from incrementing.It took me time to figure it out.The bad news is my code can't do with it.I don't know how to overcome the problem.I will appreciate all help I can get.
TIMER1 CONFIG
#include "stm32f10x.h"
#define PWM_FREQ                   ((uint16_t)20000)   //PWM Frequency is 17KHz*/
#define DEADTIME_1US               ((uint16_t)0x001E)  //1us Dead Time Insertion
volatile uint16_t PWM_Period;
 This Function Configure Timer1 in PWM Independent Complementary Mode with
 PWM Frequency of 25KHz.
void PWM_Configuration(void)
  PWM_Period = (SystemCoreClock/PWM_FREQ) - 1;//PWM Freq 20KHz
    TIM1->ARR = PWM_Period;
  TIM1->PSC = 0;
    //Channel4 configuration
    TIM1->CCMR2 |= TIM_CCMR2_OC4M_1 |           //PWM mode 1
                                 TIM_CCMR2_OC4M_2;
    TIM1->CCER |= TIM_CCER_CC4E;                //Enable Channel4 Compare
//     TIM1->DIER = TIM_DIER_CC4IE;  // Program malfunction when uncommented
    TIM1->CCR4 = 1000;                          //Increment PWM DutyCycle
    TIM1->BDTR |= TIM_BDTR_MOE |                //Enable PWM Main Output
                  TIM_BDTR_OSSR |               //Enable OSSR
                  DEADTIME_1US;                 //1us DeadTime b/w Complimentary Output
    TIM1->CR2 |= TIM_CR2_CCPC;                            //CCxE, CCxNE and OCxM bits are preloaded
  TIM1->CR1 |= TIM_CR1_CEN |                  //Start Timer1
                 TIM_CR1_ARPE;                  //Automatic Reload Enable
//Function change PWM channel depending on the Step
void Precommutate(void)
    if (Step == 1)  //Step 1
         //Channel3 configuration
            TIM1->CCER &= ~TIM_CCER_CC3E;            //Disable Channel3 Compare */
            TIM1->CCER &= ~TIM_CCER_CC3NE;           //Disable Channel3 Complimentary Compare */
            //Channel1 configuration
            TIM1->CCMR1 |= TIM_CCMR1_OC1M_1 |        //PWM mode 1 */
                                         TIM_CCMR1_OC1M_2;
            TIM1->CCER |= TIM_CCER_CC1E;             //Enable Channel1 Compare O/P */
            TIM1->CCER |= TIM_CCER_CC1NE;           //Disable Channel1 Complimentary Compare O/P */
            //Channel2 configuration
            TIM1->CCMR1 |= TIM_CCMR1_OC2M_1 |        //PWM mode 1 */
                                         TIM_CCMR1_OC2M_2;
            TIM1->CCER &= ~TIM_CCER_CC2E;            //Disable Channel2 Compare */
            TIM1->CCER |= TIM_CCER_CC2NE;            //Enable Channel2 Complimentary Compare */
 else if (Step == 2)  //Step 2
            TIM1->CCER &= ~TIM_CCER_CC1E;            //Disable Channel1 Compare */
            TIM1->CCER &= ~TIM_CCER_CC1NE;           //Disable Channel1 Complimentary Compare */
            TIM1->CCMR2 |= TIM_CCMR2_OC3M_1 |        //PWM mode 1 */
                                         TIM_CCMR2_OC3M_2;
            TIM1->CCER |= TIM_CCER_CC3E;             //Enable Channel3 Compare */
            TIM1->CCER |= TIM_CCER_CC3NE;           //Disable Channel3 Complimentary Compare */
                                         TIM_CCMR1_OC2M_2;
 else if (Step == 3)   //Step 3
            TIM1->CCER &= ~TIM_CCER_CC2NE;           //Disable Channel2 Complimentary Compare */
                                         TIM_CCMR1_OC1M_2;
            TIM1->CCER |= TIM_CCER_CC1NE;            //Enable Channel1 Complimentary Compare */
                                         TIM_CCMR2_OC3M_2;
 else if (Step == 4)   //Step 4
                                         TIM_CCMR1_OC1M_2;
                                         TIM_CCMR1_OC2M_2;
            TIM1->CCER |= TIM_CCER_CC2E;             //Enable Channel2 Compare */
            TIM1->CCER |= TIM_CCER_CC2NE;           //Disable Channel2 Complimentary Compare */
 else if (Step == 5)   //Step 5
            TIM1->CCER &= ~TIM_CCER_CC1E;            //Disable Channel3 Compare */
            TIM1->CCER &= ~TIM_CCER_CC1NE;           //Disable Channel3 Complimentary Compare */
                                         TIM_CCMR2_OC3M_2;
            TIM1->CCER |= TIM_CCER_CC3NE;             //Enable Channel3 Complimentary Compare */
                                         TIM_CCMR1_OC2M_2;
 else  //Step 6
            TIM1->CCER &= ~TIM_CCER_CC2E;             /* Disable Channel3 Compare */
            TIM1->CCER &= ~TIM_CCER_CC2NE;            /* Disable Channel3 Complimentary Compare */
            TIM1->CCMR1 |= TIM_CCMR1_OC1M_1 |         /* PWM mode 1 */
                                         TIM_CCMR1_OC1M_2;
            TIM1->CCER |= TIM_CCER_CC1E;              /* Enable Channel1 Compare */
            TIM1->CCER |= TIM_CCER_CC1NE;             /* Disable Channel1 Complimentary Compare */
            TIM1->CCMR2 |= TIM_CCMR2_OC3M_1 |         /* PWM mode 1 */
                                         TIM_CCMR2_OC3M_2;
            TIM1->CCER &= ~TIM_CCER_CC3E;             /* Disable Channel3 Compare */
            TIM1->CCER |= TIM_CCER_CC3NE;             /* Enable Channel3 Complimentary Compare */
