TCP, GPIO and Timer running at the same time
Question asked by delos_reyes.kristian on Jul 17, 2013
Hi Guys,
I want to implement a
GPIO data acquisition
UDP/TCP communication
and tick count or microsecond counting
HAPPENING all at the same time.. how can I do that?
details: my data to be sent via tcp /udp is from the GPIO ports and tick count.. i want to have the actual tick time
and how do I close the PCB? so i will not go out of stack space
  * @file    udp_echoclient.c
  * @author  MCD Application Team
  * @version V1.0.0
  * @date    31-October-2011
  * @brief   UDP echo client
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2>
#include "GlobalVars.h"
#include "main.h"
#include "pbuf.h"
#include "udp.h"
#include "tcp.h"
#include <string.h>
#include <stdio.h>
void udp_receive_callback(void *arg, struct udp_pcb *upcb, struct pbuf *p, struct ip_addr *addr, u16_t port);
u8_t   data[250];
__IO   uint32_t message_count = 0;
__IO   uint8_t  Flag = 0;
struct udp_pcb *upcb;
  * @brief  Connect to UDP echo server
  * @param  None
  * @retval None
void udp_echoclient_connect(void)
//   struct udp_pcb *upcb;
  struct pbuf *p;
  struct ip_addr DestIPaddr;
  err_t err;
  if (Flag == 0) {
    Flag = 1;
    /* Create a new UDP control block  */
    upcb = udp_new();
  } else {
      u8_t (*pointers)[250]= &data;
      for (int ctr7 = 0; ctr7<250; ctr7++)
        *pointers[ctr7] = data[ctr7] = 0;
        *pointers[ctr7] = data[ctr7] = DATAS[ctr7];
    //sprintf((char*)data, "YEHEY %s", DATAS);
    p = pbuf_alloc(PBUF_TRANSPORT,strlen((char*)*pointers), PBUF_POOL);
    if (p != NULL) {
      /* copy data to pbuf */
      pbuf_take(p, (char*)*pointers, strlen((char*)data));
      /* send udp data */
      udp_send(upcb, p);
      /* free pbuf */
      pbuf_free(p);
    //Flag=0;
    return ;
  if (upcb!=NULL) {
    /*assign destination IP address */
    IP4_ADDR( &DestIPaddr, DEST_IP_ADDR0, DEST_IP_ADDR1, DEST_IP_ADDR2, DEST_IP_ADDR3 );
    /* configure destination IP address and port */
    err= udp_connect(upcb, &DestIPaddr, UDP_SERVER_PORT);
    if (err == ERR_OK) {
      /* Set a receive callback for the upcb */
      udp_recv(upcb, udp_receive_callback, NULL);
      //sprintf((char*)data, "sending udp client message %d", DATAS);
      /* allocate pbuf from pool*/
      if (p != NULL) {
        pbuf_take(p, (char*)*pointers, strlen((char*)*pointers));
        /* send udp data */
        udp_send(upcb, p);
        /* free pbuf */
        pbuf_free(p);
      } else {
        #ifdef SERIAL_DEBUG
         printf("\n\r can not allocate pbuf ");
        #endif
    } else {
      #ifdef SERIAL_DEBUG
       printf("\n\r can not connect udp pcb");
      #endif
  } else {
    #ifdef SERIAL_DEBUG
     printf("\n\r can not create udp pcb");
    #endif
  Flag = 0;
  /*increment message count */
  message_count++;
  /* Free receive pbuf */
  pbuf_free(p);
  /* free the UDP connection, so we can accept new clients */
  udp_remove(upcb);
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
