Including startup into library
Question asked by slayer.terminal on May 27, 2013
Latest reply on May 27, 2013 by slayer.terminal
I need to create a library to my BSP so I would be able to use it anywhere.
Creating the .a file isnt that hard with CooCox IDE, but the main problem is
when I want to use the library in an application, the size of the code is always zero.
Unless I use the startup file provided by CooCox in the application.
My job is to include this startup file inside the library so it would be transparent
to the user.
Many thanks.
